Question about ASUS P4P800S-X (610839118175) Motherboard
Won't start After cleaning my computer with it unplugged my computer wont start when you hit the button to start it it will run for about 1 1/2-2 seconds then just cuts back off. the HDD and Reset wires were unplugged but are back in their right slots. Thanks in advance for any help.
  • gbuk_1976 Feb 21, 2008
    I've got exactly the same issue! ..... I've tried alsorts now! .... it just doesn't kick in at all!
    currently got it unplugged, with the battery out and a jumper on the CLR CMOS ..... any other things I could possibly try!?!?
    kicking it hasn't worked either :O(
First Pull Out The Cable That Plugs Into The Motherboard From The Power Supply. Then Plug It Back In After A Few Seconds
Posted on Mar 04, 2009
I thought i'd already tried that?! any rought idea how to do that?
Posted on Nov 25, 2008
How to reset the bios
Posted on Nov 24, 2008
  • 95 Answers
Try resetting the bios. Have seen this problem with many pc's.
Posted on Jan 21, 2008
Desktop wont start up
Need more info here please. What kind of computer is there any beep. Try to unplug your computer then while it's unplug hit the power button. Then plug Back in see if this helps
Aug 18, 2014 | Acer Veriton Computers & Internet
Lawn mower won't run. Cannot start it.
sometimes the primer bulb gets cracked and wont properly pump fuel into the carb. replacement of the bulb should fix the problem.
Jun 15, 2013 | Garden
Computer Won't Let Me Past Disc Check?
if you have any external devices plugged in such as mice or hard drive or usb unplug them and then try to reboot. check online for the brand name of your computer for "safe Mode" typically its hitting the F buttons or the delete button and going into safe mode then if it will save the file you really need. then try to reboot
Nov 12, 2017 | Dell Computers & Internet
Keyboard Won't type nothing and I Just Putted New Batterys in The Keyboard, How do i make it type?
Try resetting the computer then hitting the connect button on the keyboard after the computer has started. Or unplug the keyboard and turn the comp on before plugging in the keyboard and hitting connect.
May 25, 2013 | Computers & Internet
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
My usb drive cannot format
hi! nothing to worry! here are the simple steps to solve ur issue!
1. make sure that all ur data in that usb drive are already backup.
2. these may due to some virus which run on usb drive and wont allow u to format.!
3.try to scan with antivirus and clean then try to format!
4. still wont format dont worry! just unplug it! then restart ur pc/laptop
5. then hit F8 button before the operating system loads! hit when ur motherboard logo appears!
6. it ask u list of items! select the option "safe mode" then it again asking u to work in operating system!
7. then u may got black desktop with limited icons in it!
8. dont worry! just plug ur usb drive! open my computer!
9. right click on ur usb drive icon !
10. then hit format option.
that's it! ur usb drive now format without any error option!
Rate or comment me if u like!
Jul 23, 2011 | Computers & Internet
My maytag epic z washer wont start. When I hit the power button it does nothing as if there no power. It's getting power because sometimes I could get it to start, but now won't start. Like its a switch. I...
Unplug or disconnect power to the machine and access the electronic control board. Remove the screws in the back of the top panel, then lift the back of the top panel and slide back to remove.
The electronic control board is located on the left side near the top. It's very common for that part to fail. Look on the back side for a burned or scorched mark near the relays.
Measure the resistance between P1-3 and P1-4. If the resistance is between 1-6 ohms, replace the control board. If not check the belt switch for continuity.
Check the motor windings at the motor switch. Disconnect the motor connector. Measure the run/main windings between the blue wire in back and the white/orange wire (2.4-3.6 Ohms). Measure the start windings between the blue wire in back and the Violette wire (2.4-3.8 Ohms).
Lift the idler pulley up and measure between the two blue wires to check the belt switch.
Ref. link: https://www.applianceblog.com/mainforums/threads/44767-Maytag-Epic-won-t-start
Oct 11, 2017 | Maytag EPIC MFW9700S Front Load Washer
Wont Turn ON
(1) Hit the reset button for 5 seconds.
(2) Hit the reset button, slide down the on/off slide, and have it plugged into the computer at the same time. Hold for 5 seconds.
(3) Hit the reset button again.
(4) Charge it for at least 10 hours in the port in the BACK of your computer.
(5) After 10 hours, unplug the player and press the + volume button. While still holding it, plug the player back in. Keep holding it for 5-50 seconds. (most likely nothing will pop up).
(6) Let the player sit UNPLUGGED for a good 3 hours.
(7) Plug the player back in (it should light up now). Let it charge the usual time it takes to charge for an empty battery, about 6 hours.
Sep 14, 2009 | Creative Labs ZEN V Plus MP3 Player
How to rebot acer 4220 laptop
usually holding down the power button for a long time will force a reboot. I am not sure if that is what your asking
Dec 05, 2008 | Computers & Internet
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
ASUS P4P800S-X (610839118175) Motherboard Logo
147 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
