Question about Cuisinart DGB-600BC 10-Cup Coffee Maker
DGB-600BC Just beeps and the power light lights up only when pressed no continuous power
  • leo2 May 11, 2010
    Hi , does the coffee maker making hot? some coffee maker has 5 minutes light up and the rest are on and off due to the coffee maker adjusting the hot temperature and depends also the heat sensor boiling point.
I have had the Cuisinart DGB-600BC for a bit over a year. The coffee grinds, and then sometime during the brewing cycle, it will go, "beep beep, beep beep, beep beep..." on and on.
I think I have traced the problem to the latch on the top lid that you open to access the bean hopper. I believe the latch sticks and doesn't close the lid tightly enough. It will appear to be closed, but the latch isn't all the way in place.
So, there is a small screw on the inside of the latch in the lid. Carefully unscrew this, remove the screw, latch, and the small spring. Remember which way the latch faces.
With a warm damp paper towel, clean the latch and the slot in the lid that the latch goes into. Reassemble, and make sure the screw is not so tight that the latch doesn't move freely.
This should solve your problem.
Posted on Nov 04, 2008
  • Anonymous Dec 28, 2017
    I put a weight on lid and it started working again. Thanks
How can i get manual for Cuisinart dgb800bc
Hi Harrison, The links below are user manual for a dgb900bg and a user manual for a dgb600dg..... Could not find an 800 mate......... CHEERS..
https://www.cuisinart.com/share/pdf/manuals/dgb-900bc.pdf
http://www.cuisinart.com/share/pdf/manuals/dgb-600bc.pdf
Apr 29, 2016 | Cuisinart Coffee Makers & Espresso...
DGB-600 won't stop beeping and is missind grinder
The grinder cover has a white pin as a part of the cover that acts as a go between for the plastic molded post on the cover and a contact switch in the unit. Without the cover in place the molded post is not long enough to reach the contact switch and "tell" the machine it's o.k. to brew. It will beep incesssantly and do nothing. Get a replacement cover, or jury rig something to act as a replacement for the grinder cover pin. You can manually push in the switch to get it to stop beeping, but it will spring back out as soon as you release it.
Dec 19, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
No lights come on. Only get three black dashes on
Took it apart and saw several problems. Could not get the parts. Had this one for seven years. Used it every day. Got good use out of it.
Looked around for another new coffee maker of this type. Amazon had one for $75 and free shipping. With a $30 rebate.
Dec 14, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Need instructions to operate DGB-600BC
Thanks for the reply. Got rid of the coffee maker. Its a dud. No more information required.
Jun 18, 2009 | Cuisinart Thermal DGB-600 Grinder
Wattage of a Cuininart DGB-600
The consensus seems to be that it is 1025 Watts, although I have a hard time believing it - not even a stand mixer is 1025 watts.
Apr 01, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Coffee doesn't brew full pot
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Dec 28, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
DGB-600BC - Coffee maker (grinder combo)
Unplug for 20 minutes or longer - this one has a longer than normal reset.
Dec 07, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Power surge fried our unit
Contact cuisinart and see if the will replace it under warrenty. This happened to mine, but they would not replace mine because it was a refurbished model. I am going to rip mine apart to see if I can fix it this weekend.
Jun 18, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Cuisinart DGB-600BC 10-Cup Coffee Maker Logo
1,018 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Marvin
Marvin
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
