Question about Emerson EWV601 S-VHS VCR
Where's the Tracking Button?
I can't seem to figure out how to adjust the tracking. I'm noticing a lot of horizontal lines when playing old family movies and would like to improve the tracking, but I see no button on the VCR or function on the menu that would allow me to do this. Help!
  • Anonymous Mar 23, 2008
    the tv screen has tracking problems across the lower couple inches of screen when playing a tape. how do i adjust the vcr tracking?
  • 979 Answers
If the speed originally was LP, that would explain the problem. Many new units will not properly play LP tapes. Do other tapes play Okay?...accordianman
Posted on Jan 21, 2008
Have a Toshiba RDXV60KB. Will play some prerecorded vhs vids but not others. It's as is the tracking is out. Can I manually adjust the tracking or is it back to the repairers.
Many if the unit has a vol or channel buttons those will when in play become manual tracking adjustments, it depends if they are there or not.
Dec 07, 2012 | Toshiba DVR660 DVD Recorder/VCR
How do you adjust the tone arm on a Denon DP-47F turntable? Thanks Cosmicharlie
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Apr 14, 2011 | Denon DP-47F Turntable
Can't figure out how to adjust VCR tracking
Open the player, use cotton wool and methylated spirit to clean the play head of your tape player and the picture will be clear. It is dirt that is making the picture shaky.
Its not all the time that tracking can solve the problem. So clean the player's play head and all will be well.
Please don't apply too much spirit and make sure you dry it with a dry wool. Also make sure the player is turned off and removed from electricity before you proceed for the cleaning.
This is the help that I can render to you.
Good luck.
Apr 23, 2010 | Quasar VHQ401 VHS VCR
Memorex MVD4544
Low FM from the video heads is a common cause of this lack of tracking.
Jul 13, 2017 | Memorex MVD4543A
Streaks in playback
the first thing i would do would be to try a head cleaning tape-if that doesn't help see in your book or menus if you can adjust the tracking on the camcorder-when the tape heads get worn over time they need to be aligned and that is what tracking does-some older models allow you to manually adjust-good luck!
Jun 12, 2008 | Canon ZR60 Mini DV Digital Camcorder
Tracking seems off
I have had the same problem. There is no way to manually adjust the tracking on this Hitachi, or on most 8mm cameras, for that matter. I copied all of my more recent tapes to DVD first (2 copies of each) and then I went to the oldest tapes, which for some reason were OK. When I got to one tape that gave me trouble, I just let it play in the camcorder for about an hour. It adjusted its own tracking so that the picture was OK. Then, I rewound the tape and copied that one. I still have 2 tapes that will not adjust. I am going to send those out to a copying service. I hope they can adjust the tracking and make the copies I need.
By the way, I used this camera and a Panasonic DMR-E55 to make the DVD copies.
Jun 04, 2008 | Hitachi VME545 Camcorder
Panasonic DMR-EZ47V Fuzzy horizontal line in VHS mode
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
May 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Old Betamax Sony SL2300 Possible Tracking problems
A common problem with this model and others is the tracking pot itself fails. Wiper in pot breaks loose. Test if the tracking control has any effect?? If not, pot is bad.
Other causes are dirty heads and tape path but, the tracking control should always have some effect on PB pic. Bad video head, tape guides loose( tape not tracking on video head correctly), guide pin problem on loading ring, slack brake problem, etc.
Nov 05, 2007 | Sony Playstation 3 (PS3) Console
Emerson EWV601 S-VHS VCR Logo
150 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
