Question about Microwave Ovens
Reset my clock
How to reset the clock on my my swan microwave oven model number sm1100w
  • Anonymous Mar 15, 2014
    reset timer
  • Microwave Ovens Master
  • 9,098 Answers
Normally you press Clock, then the numbers, then either Clock again or Start.
If that does not work, you should call the dealer or store where you got the oven to see if they have a contact number for Swan.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 27, 2008
I cannot reset clock
Touch Timer/Clock pad and number 2 pad.
Enter the correct time of day by touching the numbers in sequence.
Touch Timer/Clock pad again.
Aug 15, 2015 | Sharp Carousel R530EST Microwave Oven
I have a swan microwave oven sm1100w but have lost instructions :( can you tell me how to use the defrost options?
On most brands, you do with key sequence like this:
(for 1 minute of cooking at 30% power)
Cook Time > 1 > 0 > 0 > Defrost > 3 > Start
Apr 28, 2013 | Microwave Ovens
Got swan sm2060R microwave. Plugged it in clock is set but no functions working
test the power outlet plug some lamp desk if work is o.k if NOT reset the c. breaker. follow this stepFirst check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
God bless you
Apr 04, 2013 | Microwave Ovens
Kenmore pizza microwave beeps constanly
This is not a solution, it is a clarification request, but it looks like FixYa took away that helpful option, too.
I would suggest you post a whole new help request and be sure to tell us:
1. The FULL model number from the tag in or on the microwave. A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
2. Let us know when it beeps. Is it only after cooking? While it's setting idle?
3. Next, let us know if the display has anything in it besides the normal clock time.
A good first step might be a hard reset, accomplished by unplugging the oven for a minute or two, plugging it back in, then resetting the clock.
Dec 11, 2012 | Kenmore 20" 1.1 cu. ft. Pizza Maker and...
How do I unlock the touchpad of my Profile 2.0 Spacemaker Microwave Oven # JVM2070
If you have access to where your microwave is plugged in, unplug it for a few minutes and then plug it back in. This will reset your contol panel. Then follow your book directions to reset the time on the clock. Hope this helps!
Nov 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
On most microwaves you simply press (Clock) then push in the time with the number pad, then you press start button.
This is how most will set, some models will also have am/pm options.
If all else fails then get the model number of your microwave and make/Brand and go to the manufactures website, for instance if its whirlpool type in and go to the section for manuals and it usually will ask you for your model number.
Good Luck!
Nov 04, 2009 | Welbilt Microwave Ovens
Cant set the clock
In most brandsof microwave oven, you set the clock by one of these combinations of key presses:
Clock > time digits > Clock
Clock > Clear > time digits > Clock
Clock > time digits > Start
If that doesn't work, please reply back with your brand and full model number.
All the best and do rate this answer if u r satisfied.
May 10, 2009 | Microwave Ovens
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
- To reset the present time in the display window when the oven is off, press the CLOCK button and
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
Microwave Ovens Logo
179 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
