Back to:
Tags:
Samsung - Projection TV replacement lamp Projector Lamp
Problem with samsung HDTV (by 3 users)
posted by Shady Grady on Jan 21, 2008
The T V screen has green lines curving from the top of the screen. Can you help i was told maybe it was the convergence?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by copelin, posted on Jul 02, 2008
Same problem here. Ghosts appeared and now the TV seems to overheat and shut off after on for a few hours. A repair man came to look at it ($89) and now it doesn't even turn on. The repair man then said we need a new panel (or something like that) and it will cost another $320.
Comment by Guest, posted on Jun 24, 2008
I'm having the same problem but the Blue is the problem.
Solution #1
posted on Jun 22, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have ghosts on screen. What is it and can I fix it myself
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on problem with samsung HDTV:
I don't want to Accept this solution
Can you Help with these Multimedia Projector Replacement Lamps problems?
Samsung - Projection TV replacement lamp...
Please Help! Samsung DLP TV Model HLR 5667WX/XXA TV made a...
yes my tv just starting humming when it is turned on and...
First Problem--Sometimes when you change the channel, the...
The TV makes a humming sound , but the power light just...
My old lamp was getting a beautiful picture but would only...
Loading problems.
Repair Service
Find Multimedia Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
