My washing machine, after washing, changed to the spin cycle then started beeping so I turned it off, re-started it & when it got to the last spin cycle it just beeped then stopped. Now it wont start. It's almost like there is no power
    Problem Solver:
  • 19 Answers
No power? Let's see if we can solve this problem.
  1. Unplug then plug back again.
  2. Start the program.
  • If beeping send for repair/replacement.
  • If not beeping be happy to continue using your washing machine.
Posted on Dec 12, 2010
  • 51 Answers
SOURCE: Wont Spin
Hi Vixxy, Which lights flash when you hear the beeping?
Posted on Jul 24, 2007
  • 15 Answers
SOURCE: Washing machine wont spin the water out.
IT IS VERY POSSIBLE THAT YOU HAVE A BAD OUT OF BALANCE SWITCH. THE MACHINE WILL NOT GO INTO A HIGH SPEED SPIN IF THE SWITCH IS BAD.
Posted on Apr 07, 2009
SOURCE: Fisher & Paykel GW712 washing machine continuously
Out of balance switch could be faulty/ coroded.
have a gw 709 and it had the same problem, out of balance switch had jammed on
Posted on Apr 15, 2009
  • 713 Answers
SOURCE: My washing machine stopped at the spin cycle and
Hi just read your posting.Now when the machine beeped, a series of lights would have lit up.They will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine beeps,Is it the 2nd and 4th or the 1st and 6th ---etc---?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Posted on Sep 03, 2010
  • 6277 Answers
SOURCE: Fisher and Pykel washing machine.
(try this but no promises!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 29, 2011
How do I reset my Fisher Washing machine size?
To set the size switch, turn the power on at the power point and off at the console. Press and hold
WASH TEMPERATURE UP then press POWER. EcoSmart will give 4 short beeps
and the pattern of LEDs will change.
To lock the size into memory.
 Press SPIN SPEED UP, the SPIN HOLD LED is on for 7.5 / 8.0kg (650mm wide).
 Press POWER to confirm the setting and also exit this mode.
Apr 15, 2015 | Fisher Paykel EcoSmart GWL15
Why my washing machine will start the wash cycle but will not spin or rinse?
the drain pump is probably blocked or overheating, when it starts beeping which lights are flashing reading from right to left e.g. 1,3,5 also what is the model number?
Aug 17, 2014 | Fisher and Paykel Washing Machines
Simpson 605 washing machine
it is worth having it properly diagnosed first before making a decision to spend money
could be a program board or start run capacitor
Nov 11, 2017 | Washing Machines
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Model Gw709AU
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Feb 20, 2013 | Fisher and Paykel Washing Machines
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Zanussi washing machine is making five beeps and not workign - what does this mean? It is not in the manual
My Zanussi Fs1555w is not finishing it's cycle and beeping 7 times. If I put on spin the cycle lasts less than a minute before the end button beeps, then it will beep repetitively 7 times until turned off. Please help
Feb 05, 2010 | Zanussi FS1455W Front Load Washer
GLW10US won't do anything but beep
well i don't have any experience with this brand but i would say you need to change the fill switch it senses how much water is in the tub shuts the water off then starts the washer its also called the pressure switch
Feb 16, 2008 | Washing Machines
Washing Machines Logo
250 people viewed this question
Top Washing Machines Experts
