Question about Brother MFC 210C All-In-One InkJet Printer
Ink message MY BROTHERS 210C MESSAGE READOUT CONTINUES TO SAY THAT THE INK LEVELS ARE ALMOST EMPTY EVEN THOUGH I JUST REPACED THEM. ALSO FREQUENTLY THE PRINTER TURNS ON WHEN SOMEONE CALLS
  • 832 Answers
Same issue:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000300/000036/faq000336_002.html?reg=us&c=us&lang=en&prod=mfc210c_all
You have to change the incoming call/fax settings. plz see manual for the right settings (chap. fax)
Posted on Jan 21, 2008
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
I replaced the inkjet cartridges in a Brother 210c All in One and it still shows low ink levels in the color cartridges (Black is fine). Where do I need to troubleshoot?
Just unplug the machine and plug it back in while you hold the stop key for about 10 seconds. Usually clears up and resets ink levels.
Nov 25, 2009 | Brother MFC 210C All-In-One InkJet Printer
MFC 210C Ink Problems
Steve,
did you watch the display after replacing the cart?
Very often the machine asks if you have changed the cart and demands an answer (1 for yes).
You can try to do an update of the firmware, too. Go to www.brother.com , choose your country and then your machine. Download a small update tool and run it.
If it aint getting better:
Do unplug from power outlet (even though you have done already) wait 10 Min. leave scanner cover open and take all carts out. Plugin to power again and leave scanner open. Wait uintil machine gives a warning signal. Reinsert carts and close cover: now watch the display and give always the answer YES(1).
Mar 04, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-in-One Ink Cartridges
near empty message is a reminder: plz buy a new cart (but do NOT change until EMPTY). You still can print.
the ink left in an empty cart keeps the system alive when some ink is neede for the automatic cleaning cycle.
If you print until this cart is really empty air will get into the tubes and ph. That leads to faulty printings.
brother had made sure that the amount of printable ink can be consumed. The rest is for service.
Jan 31, 2008 | Brother MFC 210C All-In-One InkJet Printer
Ink problems....
Take all carts out of the machine. Have a look into the cart holder. Is there ink swapping beneath the white plastic? (You might shake the machine ;-)
If yes, the cart holder leaks and needs replacement.
If not (your lucky!) it could be that the automatic cleaning procedure which starts when a cart is changed has soaked the carts empty.
Do set machine with date and time and NEVER unplug NOR use a power switch which breaks the power supply.
Do use constant power and switch off machine by pressing stand-by-fax-button!
Everytime when machine comes to (new) power contact it runs an extensive ink cleaning procedure. thats why your carts are always near empty....
The stand-by will prevent this and machine does some cleaning procedures which consumes only a few drops(!) of ink!
The display asks you if you have changed the carts. Do answer this question by pressing 1 for YES or 2 for NO.
This will reset the built-in inkcountermanagement to the correct settings
Jan 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
Replace Cartridge,Ink Emty Black
see here:
http://www.fixya.com/support/t213275-say_new_cartridge_yellow
Do use original ink carts because thirdparty ones have a different construction and wont be accepted by printer sometimes.
When (re-)inserting press ink cart into assy and clip the support over the edge.
Please check the other carts, too. They may be empty.
Oct 15, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
60 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
