Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE side-by-side freezer not freezing.
I have a GE PSS25MGNAWW that all of the sudden not freezing any more. I've notice that the ICE has thawed and froze at a certain point. Is there a quick way to try to isolate the problem? I tried defrosting it and notice high build up of ice in the evaporator. Any help is much appreciated
  • durbon Jan 18, 2009
    I have the same problem for the second time in 6 years. The fan starts to whine and stops circulating then quits altogethe. The repairman replaced the fan the first time only to have to replace the units computer board because the fan didn't fix the problem. This is a defect in parts or design if it goes out every 3 years. Unless I can figure out what is causing it, I'm getting a new fridge.
  • 236 Answers
Defrost the unit until all ice melts( force defrost by unplugging the unit for several hours). Then plug and start the unit check if the blower inside is operating. If no air present in the vents check for stock up blower motor. If blower is operating and air is present in vents. Mas be the unit is out of gas.
sample only:
Posted on Jan 21, 2008
GE profile side by side fridge freezing and thawing randomly
Defrost entire unit, put food in coolers with ice and unplug. Wait 24 hours with doors open. Any clogs in freon lines should be gone, plug unit back in and see how it works.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Jan 24, 2014 | GE GSS22SGM Side by Side Refrigerator
The water is leaking from the Ice dispenser and the food is thawing
Seems like the freezer is not getting cold enough. If the ice maker was leaking the water would freeze. It would not cause the food to thaw.
Oct 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
No water from door dispenser
BAD WATER VALVE OR CHECK FOR CLOGGED FILTER
Jun 18, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Freezer not cooling enough to make ice.
well countney778 it sounds like either your drain is clogged upo and holding water in the freezer or your defrost timer is bad. the timer shoiuld be by the thermostat area and the drain is at the boittom of the coil that is currently freezing. also look underneith and if you see abunch of dirt then you may have to clean the coil on the bottom of the unit. use a shop vac and a long brush to clean.
Jan 19, 2009 | GE Refrigerators
Ge profile refrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Refrigerators
Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
May 07, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer thawing and refreezing
The freezer is supposed to thaw at least everyday. Only, you usually kant tell because it doesn't do it long enough to melt the food so you don't notice it. You have a couple of components to check here. 1 is the defrost timer, which unless it has been changed recently, has the same pre determined defrost time. So you would have noticed by now. Next is the defrost termination switch. If you have excess ice on the evaporator, this will make the defrost longer than before. Unless the switch is going bad causing the defrost to go extra long, there is an excess amount of ice that is more than usual. Bad door seal will cause this. A slightly low freon charge. And a thermostat that is malfunctioning, causing the freezer to run continuously, will make excess ice buildup in the freezer. I would make sure the kids aren't leaving the door open and the gaskets are good. If not the case, call a repairman.
Jan 09, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
1,963 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
