Question about Yamaha RX-V2700 Receiver
No sound from Zone 2/3 speakers
I have set up Zone 3 for SP2 for Int Amp and have not heard any sound from the zone speakers. I have followed the operating manual to the letter even checked the Bi-Amp is set to off, is there a way of checking the Int Amp to see if it working.
  • 1 more comment
  • Anonymous Apr 14, 2008
    no sound from Zone 2/3. It worked very first time I was testing. Since than never worked.
  • Anonymous Oct 23, 2008
    My zone 2/3 seemed to be not working. I tried playing the IPOD and the CD (via DVD) but to no avail. My DVD is connected to an HDMI port. Are both my IPOD and CD player (via DVD) using digital output instead of analog? Could this be the main reason? I tried the radio but still giving me the same problem. THANKS!
  • dsilly Apr 17, 2009
    My zone 1 is working great through all HDMI input/outputs, but can't get zone 2/3 to work. One time I got tuner (radio) to come out of speakers, but can't get anything else to work. I am using manual too!
Had the same issue ...only resolved it by adding the analougue inputs for other components as zone 2 didnt seem to work with optical inputs i had for main speakers
Posted on Jul 05, 2008
  • 3 Answers
Make sure that you are selecting the sp2 to be working with zone 2/3. Be careul and check volume to zone 2/3 on front panel before you activate sp2 with zone2/3.
Posted on Apr 16, 2008
Fix volume control
1. Go into the Set Menu.
2. Press the AMP button on the remote.
3. Press the Menu/Set Menu button.
4. Use the Arrow Up Down button to select Manual Setup.
5. Press the Enter button to enter Manual Setup.
6. Use the Arrow Down button to select the number 3 Option Menu.
7. Press the Enter button to enter the Option Menu
8. Use the Arrow Down button to select D Multi Zone Set.
9. Press the Enter button to enter D Multi Zone Set.
10. Press the Arrow Down button to get to Zone 2 Amp
11. Press the Arrow button to the right to set the Zone 2 Amplifier to INT.
12. Press the Menu/Set Menu button repeatedly to exit the Set Menu.
I’m happy to help further over the phone at https://www.6ya.com/expert/glenn_3b3dd885737c06f6
Aug 09, 2014 | Yamaha RX-V757 Receiver
Hi- I have a Yamaha htr 5990, I am trying to set up a 2nd set of speakers to run off zone 2 or 3 that will power speakers at the patio; but I cannot figure out how to get it to run. Any suggestions as...
to set up a zone 2 or zone 3 set up you need the yahama amps that receive the signal from the main amp, and from that zones amp, you can control that zone, If you check out page 102 of the manual, you will see where it shows these external amps that control that 2 nd and 3rd zone However, if you look at page 85 of the manual, you can just run the speakers off the main, and select B on the speaker selection, leaving main and B on will have sound coming from all the speakers, turn off whichever you want to cancel the sound in either room
Jul 11, 2011 | Audio Players & Recorders
I have a yamaha RX-4659 receiver and my Zone 2 (outside speakers) had been working great for the last 3 summers. Now, I am unable to get any music to my outside speakers. When I try to adjust volume for...
Zone 2 has been switched to "EXT" in the setup menu. Switch it to "Amp" or "Int" and it should be fine. It thinks you are using an external amplifier. If you need further help, post a reply and I will help you further. Hope this does the trick for you!
May 30, 2011 | Audio Players & Recorders
In regard to my Marantz AV Surround Receiver, Model number SR5005, I cannot get the Zone2 speakers to play. I have followed all the instructions, and nothing works. Does anyone know what I need to do...
have the same model. just got it to work. but, struggling with one part. here's the scoop. 1. Plug your second zone speakers into the SURR BACK/AMP ASSIGN speaker outputs on the unit. 2. You need to "amp assign" the speakers to zone 2 by pressing AMP, MENU, select SPEAKER SETUP, AMP ASSIGN and scroll to ZONE 2 - this will force the sound to the speakers that you plugged in. 3 - Turn on Zone 2 (press Z2, press ON button on remote). Use the UP/DOWN arrows to select the input for Zone 2. I've only been successful in selecting USB and plugging my iphone in for zone 2. For some reason, I cannot get the SAT (cable box) to play in both zone 1 and zone 2 at the same time. But, I can get SAT in zone 1 and USB in zone 2. Hope that helps. Let me know if you can solve my issue...
Apr 13, 2011 | Marantz SR5005 Receiver
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Zone 2 problem
I know this is old and im sure you have it solved by now, but it might be a good idea to check the amp setting of Zone 2. Is it switched to Internal or external? I remember something strange about this amp in that when you change from using the rear surrounds and go to use them in Zone 2, it resets the amp setting or something like that. Hope it helps if you still need it.
Sep 15, 2008 | Yamaha RX-V659 Receiver
No zone 2 sound coming from yamaha amp rx-v861
We had the same problem - I think it was reset when the power went off in a storm. Went to Yamaha website (http://www.yamaha.com/yec/faq/faqdetail.html?CNTID=206010&CTID=5009135) and found the following worked:
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control [SIDE SELECTOR SWITCH] to [AMP]. (Located to the right of the volume buttons on the Remote).
  2. Press the [SET MENU] button on the remote control.
  3. Arrow down to Manual Setup and press the [ENTER] button on the remote control.
  4. Arrow to the Sound Menu option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
Feb 16, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V657 Zone 2
Suggestion by clarkent22
I called and spoke with Yamaha support staff (Chuck) who was very helpful. I was able to get my issue resolved hopefully this works for you too.
Couple of solutions:
1) Go into the Menu setting (Manual SetUp/Speaker Set) and make sure that you do not have Presence Speakers or Suround Back Speakers
2) Also in the Menu settings (Manual SetUp/Options/Multi Zone Settings) make sure that your Zone 2 Amplifier is set to "Int" (assuming you are not using external amp
3) Zone 2 can only accept an analog signal (not digital)... so there are two steps to this one. First, make sure that you either run only analog, or if you run digital and analog then you need to select "Analog Input" on the front of the unit. If yours was working earlier, my guess is that your input settings got switched to digital (or auto) You need to have analog set up for each specific external source (DVD, Cable/DTS, etc)....
4) This model receiver will only let you control Zone 2 with the remote control. You can power it on the receiver unit. But to select your source you have to press the Amp button, then the ** button. Then you control Zone 2 and you can toggle sources and adjust volume. (Check your owners manual for programing remote for zone 2.. think I pressed the "code" button and then 2999.)
Hope this helps... it worked for me If not call Yamaha they were very helpful.
Oct 13, 2007 | Yamaha RX-V657 Receiver
Outdoor speaker hook-up
Go into the manual setup on the GUI then go to the zone 2 and zone 3 setup. If you are using only the power from the receiver to power the speakers, make sure the setting is for Zone 3 amp "INT" if you still have no volume, on the front of the receiver look at the display, make sure "zone 3" is lit up then use the small remote and turn up the vol. if it's on you will see "zone 3 vol" and the bar going up it should be ok. if it says "fixed" it thinks you have an external volume control, if you do, make sure it's "on" at about 12 o'clock and test. If not, you need to switch it in the on screen "menu" or "GUI" button, follow to zone 2 & 3 vol control and make sure it is set to variable. If you still have no vol post a comment and we can dig further. Hope this helps
Aug 18, 2007 | Yamaha RX-V2600 Receiver
Yamaha RX-V2700 Receiver Logo
418 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
