Question about Grundig G4000A FM/AM Radio
No sound Cannot get any sound from radio. Radio is a couple years old, and did work previously. Tried AM/FM & SW. Tried reset button. Replaced batteries, and started from the beginning as instructed by manual. All digital displays work, just no sound.
  • 2,130 Answers
Is there a headphone jack? If so, try a pair of headphones. If you hear sound in the headphones, the main speaker may have gone bad. If you don't hear sound in the headphones, the audio output stage may have have gone bad.
Good Luck,
- Jim
Posted on Jan 24, 2008
No sound from radio
My FM band stopped working. AM and casset still worked. Found parts car, replaced radio, all is good. The FM display still worked-no sound.
Terry
Jun 02, 2012 | 1995 Jeep Grand Cherokee
My Grundig S350 won't turn on. I have replaced the batteries and hit the reset button and still nothing. Please help.
Its Deluxe Version the S350 DL can use two types of batteries: D-size or AA. Inside the battery compartment there is a switch to select the size in use. If you use the AA sie batteries, they will not hold in their locations unless you lower a flap and secure them.
Have you tried to power the radio with the adaptor?
Aug 27, 2011 | Grundig S350 AM/FM/SW Radio
I have used my Grundig S350 radio almost daily, for the past 6-7 years. I went on vacation for 10 days. When I returned home, I turned on the power, lights light up, etc., but no sound...no matter how...
Hi
Its microcomputer chip may have hanged. Just make a reset ans see whether it helps you. It must help you, i"m sure. To reset it;
S350 incorporates with micro computer chip (the component that
controls how the radio operates). If the radio has been subjected to
abnormal environmental conditions, the micro computer chip may
hang up and the following symptoms may appear
The display shows nothing and the radio cannot be turned on by
pressing POWER & SLEEP button.
The display shows random characters or does not work properly
although the radio can receive stations normally.
In these cases, you might need to reset the radio. To reset the
S350, unplug the external adaptor (if one is being used) and
remove the batteries from the battery compartment. Insert a
pointed object, such as straightened paper clip, into the RESET hole
on the right, front side of the radio and gently press and release the
button inside the hole. Then plug in the AC adaptor or reinstall the
batteries
OK.
Jul 13, 2011 | Grundig S350 AM/FM/SW Radio
My 4 year old YB P 2000 suddenly quit broadcasting AM. I took the radio apart and cleaned everything. Now only some FM stations and no SW reception. Can you help?
Look at the front case and locate reset hole. Insert cocktale stick or similar and listen for slight click. Insert new batteries, ensuring correct polarity and that there has been no leakage from old batteries on terminals. If leakage ie green/ uneven appearance, try to scrape clean with suitable implement when disconnected from mains only.
Feb 10, 2010 | Grundig Yacht Boy P2000 AM/FM/SW Radio
Grundig S350 not powering on
Is there any easy self-fix that can be done to get the radio working again?
Nope. I'll bet you have some corrosion inside the switch itself.
Unless you can disassemble that you will have to send it in. If the switch had metal contacts, you could try just a tiny shot of cleaner in the switch, then work it off and on.
If you are able to get to the switchs' contacts, you can short those and see if the radio powers up. Just make sure that you have the right connections.
Bad idea bout wpraying it down with cleaner. If that suff gets in the coild or other parts like the tiny tuning capacitor, it can melt together inside, or at least cause it to be off frequency.
Good luck,
Apr 05, 2009 | Grundig S350 AM/FM/SW Radio
Kaito 1103 Shortwave Radio
I dont have this radio but I remember reading that you push the volume button then turn the tuning knob to change the volume.
Sep 23, 2008 | Kaito KA1103 SW/FM/AM Radio
User Guide Or Maual For S350 Grundig
http://www.monitoringtimes.com/html/Eton%20S350.pdf
Jul 04, 2008 | Grundig S350 AM/FM/SW Radio
Grundig Satellit 800 powers on but no sound on any bands or modes. It appears to have a signal on AM but nothing on FM. It's completely dead and the MAIN large tuning dail will not function either. All...
HI,
THE FIRST THING YOU HAVE TO LOOK FOR IS WHAT KIND OF ADAPTER 9V 1AMP YOU SHOULD
HAVE FOR THAT PARTICULAR RADIO AND ANTENNA FOR SW AND FM SHOULD BE CONNECTED.IT MUST BE THE ADAPTER THAT'S ON THE OUTS NOT ENOUGH VOTAGE TO POWER THE RADIO.
Jun 30, 2008 | Grundig Satellit 800 AM/FM/SW Radio
I can't get it to turn on.
First, make sure the batteries are good and capable of being recharged. Before setting the time, depress the 'Reset' then set the time. If set does not come on when the On-Off button is pushed or comes on and immediately turns off - depress the 'Reset' button a couple of times and then reset the clock and try the On-Off button again.
May 30, 2008 | Kaito KA1103 SW/FM/AM Radio
Sangean ATS 606 A Portable Radio
Remove the battery compartment door and the batteries. There should be a small hole marked "reset" under the upper battery cradle. Press (gently...until it clicks) and hold for 5 seconds. Replace batteries and try again.
Aug 15, 2007 | Sangean ATS 606 AM/FM/SW Radio
Grundig G4000A FM/AM Radio Logo
324 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
