Question about Kenmore Elite 21086
Kenmore elite calypso 21086 top load
My washer reads (SL) OR (5L) and then shuts off.. is there a solution to my problem? also the (LS).. is the lid switch then also what would i do to fix that.. ???
  • 15,935 Answers
SL = Suds Lock
SL is a suds lock code it can be caused by the drain pump not draining the water, too much detergent, non HE detergent, or extra heavy loads, try running it empty, if code persits it is a computer/main controller/timer failure
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Kenmore calypso washer short cycles on rinse/spin cycle and gives OP and FS error codes when trying to force a drain in diagnostic mode.
Magnetic reed switch on left side below the gray rubber bumper, shown here...
Release two spring clips in front between main top and front panel using putty knife. Lift the main top and access the left and right door locks here.
To access and see if the magnet is in place, remove the dispenser from lid.
Gently pry the bottom of the plastic inner lid toward you then down. This will let you see if the magnet is in place on the right front corner of the inner lid.
Seems to be a common problem with this washer. Apparently, the lid isn't completely watertight and allows water to get into this switch corroding the contacts and the wires.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 15, 2010 | Kenmore Elite 21086
I have an error message that reads ob. I have an
OB MEANS OFF BALANCE if the motor controller detects an unrecoverable off-blance condition, the machine controller will shut down and display ob. the lid switch must be opened at least once before restarting the cycle if this condition occurs. opening the lid will allow you to view and redistribute the load. press stop/cancel to clear the display. hope this helps.
Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite calypso 21086 leaves dirt streaks on clothes
Run the hottest & fullest cycle possible - without a load - and add a grease remover - like goo-gone. Fatty tissues build up inside the tub - and can be released on hot cycles if HOT wasn't used very often.
It is recommended to run a HOT load every 2 weeks or so to avoid these buildups and staining of clothes.
Feb 20, 2009 | Kenmore Elite 21086
L5 flashing on my calypso washer
The error code is actually a LS not L5, it stands for a lid switch error, it could be a bad lid switch or you may have forgotten you had a previous load in and went to rewash and went and started the machine without opening the lid which automatically throws an LS check the lid switch .hope helps p-ls appreciate by rating as fixyaa
Feb 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso
The original manual has a troubleshooting guide that has this for the ob code:
"Off Balance Is the load unbalanced? Redistribute the load. Cloase lid and press START. "
Hope this helps.
Sep 21, 2008 | Kenmore Elite 21086
Kenmore Elite Calypso Washer
I'm in the process of tearing apart my Calypso, Ugh. I found the diagnostic chart inside the machine. 5L is actually 'SL' which means suds lock, and can be an indicator of a failed pump, an extra heavy load, excessive detergent, or excessive suds. Corrective action is to press Stop/Cancel to clear the display.
Mar 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
21086 reading sl
If it is top loading one, you use powders for 'top loading machines'. If yours is a front loader pl use powders for 'front loading machines'. It makes a big difference in cleaning.
Feb 23, 2008 | Kenmore Elite 21086
Washer kenmore elite calypso 21086
promblem with the lid switch is it happing durning the drain spin cycle
Jan 20, 2008 | Kenmore Elite 21086
Washing Machines Logo
309 people viewed this question
Sal De
 Brian Main
Brian Main
