Question about Sony Cyber-shot DSC-W50 Digital Camera
Sony dsc-w50 flash going off before or after shutter has opened and closed
Ever since taking the camera on my hols.... the flash doesnt seem to coincide with the shutter opening resulting in v dark pictures..this seems to happen 60 percent of the time...the camera was bought back in dec 06..it was fine up until nov 07...
  • 2 more comments
  • frodoq Jan 25, 2008
    I have the same problem. And like 'starzy', it only started happening a year after i bought the camera! Please help
  • Anonymous Jun 03, 2008
    Same thing here, I got my camera in Dec. 06 and it just started doing this today June 3, 2008. Sometimes pics are too dark, sometimes they are bright white from too much flash and the flash makes a strange popping sound when it will be too bright. This sucks!
  • Mufi Lotia Jun 11, 2008
    I have this problem where images are either too dark or too bright. I looked in the user's manual in the trouble shooting section and as per the instructions changed the Metering mode to "Multi AF". This helped a bit in a way that now images are never too bright but the dark pictures still persists around 6 out of 10 snaps.
    Please help.
    Muffadal Lotia
  • Anonymous Aug 06, 2008
    Same problem! 1 years use. Any possible solutions yet? This seems to be more of a hardware problem that a switch setting because you can shoot the same subject repeatedly under the exact same conditions and get too bright, too dark or a normal shot.
  • 74 Answers
Hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and
Posted on Oct 17, 2008
6ya staff
SOURCE:
I have a Sony DSC-W50 Cybershot camera that won't take pictures or videos anymore. It powers up fine and the screen works, but when I hold down the shutter button all the way, it focuses and nothing more.
I have a Sony DSC-W50 Cybershot camera that won\'t take pictures or videos anymore. It powers up fine and the screen works, but when I hold down the shutter button all the way, it focuses and nothing displayed
Mar 07, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
How do i get rid of the shutter delay and multi flash while taking a picture with my sony dsc-w55
If you have your flash set to "red-eye flash", it will fire "pre-flashes" to prevent redeye in your subjects. You can turn off that feature and set it for normal flash. As far as shutter delay is concerned, all you need to do is press the shutter button half-way and allow the camera to lock in the focus (it will beep) and then you can re-compose the picture and press the rest of the way when the moment is right.
Dec 10, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
The Screen always shows black and it takes all black pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 07, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
I have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing...
i have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing its takin pictures as normal just without the flash it wont let me change the settings of the flash at all
Jun 14, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
Sony cyber-shot dsc-w50 problem
Hi!
It's a flash error. Could be flash fuse or flash board. If you have a multimeter and you're ready to open it, contact me at [email protected] or contact your local Sony service center.
I work in a Sony service center.
Tom
Jul 27, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
When i turn on the camera ( sony DSC W120) the shutter opens and
The focus is stuck. You should contact your local Sony service center. If they ask too much, you can contact me at [email protected]
Tom
Jul 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cybershot DSC-W50 shutter will not open
turn on when lense comes out take by end of lense and gently twist and pull you may here a click but do not force it. then turn on and off again this should solve the problem .
Aug 16, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Flash is inconsistent
I have the same issue. One picture the flash is perfect the next there seems to be a "half" powered flash and the pic is dark
Dec 09, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cybershot w50 zoom problem
Take it to a warm place to thaw out then try. If no joy then assume it has broken. If broken then it is not likely to repaired at reasonable cost - check out Sony for an estimate
Sep 10, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
SAND IN MY SONY DSC W50 CYBER-SHOT CAMERA
Hi there, this job is for a pro. Please do not try to open the lens. However there is a way and I will help you. Please contact me at live session. Arpi
Jun 11, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
71 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
john cordey
john cordey
Are you a Sony Camera Expert? Answer questions, earn points and help others
