Question about Maytag Atlantis MAV6000 Top Load Washer
Fuse problem I own a Maytag MAV 6000 AWW washer, and I think the fuse is burnt out. I would like to replace it, but I don't know where it is on the washer. Can someone please let me know where and how I can take out the fuse from this washer. Thank you.
  • 770 Answers
Looking at the manual there maybe a 10Amp fuse the manual says"If Equipt." on L1 then feeds the timer. post your email and i will send you the manual
Posted on Jan 27, 2008
  • Gary Davd
    Gary Davd Jan 27, 2008
    Note: its on page88
How to control water levels in Maytag TOP LOAD WASHER, model #MAV 6000 AWW
What is the problem?
Water level is automatically controlled based on what you set it to low, med, or high.
Jul 14, 2017 | Maytag Washing Machines
Maytag MAV 8260 AWW Does not work at all. No water flow, no spin (even when filled with water from hose) Does it have an internal fuse? Where is it located? Is the large timer switch the brain of the...
Some model have fuse in top control panel, check lid switch, yes large button is the brains, it sometime can fail but usally only takes out 1 of the cycles.
Nov 02, 2013 | Maytag MAV7600 Top Load Washer
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
I have a Maytag Atlantis MAV 7600CGW that keeps blowing the 10A fuse prior to the switch mechanism. This has happened 6 times in the last 12 months. Every time it is the 1st load after after a heavy load...
HI,
I have found the possible cause to your fuse problem, I would suggest replacing your lid switch to the unit, this can cause you fuse to blow. Item #3 below is the switch Part# is 22003804, I and hopeful this will correct the problem for you. Is part should con with the Item #7 in the picture also, replace them both, made even be a different color. I think gray is the color right now.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 28, 2011 | Maytag MAV7600 Top Load Washer
I have the maytag washer mav 7000 aww; The Timer does not work automatically but works when moved by hand to each function. This is a 120 volt 60Hz machine and since i stay in a country, where we...
Open the control console.
Use a voltmeter to test the timer motor.
Set the machine to wash.
Place the meter leads on the 2 timer motor wires.
If you read 120 volts and the timer does not advance,the timer motor is bad.
The complete timer will need replacing.
Sep 22, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top loader MAV 8000MWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Checkto see whether power is getting to the washing machine. Is it pluggedin? Has a fuse blown or is a circuit breaker tripped?
Lid switch Ifthe lid switch is defective, your washer can't spin and may notfunction at all. The switch is inside the washing machine main housingnear the door frame. Often you have to raise or open the top or frontof the washer to get to the switch. If it's defective, you need toreplace it.
Some machines have a special lid-switch fuse nearthe lid switch, inside the control panel. If this fuse blows, the unitwon't fill with water until you replace the fuse.
Sep 27, 2008 | Maytag Atlantis MAV8000
MAV Atlantis 6000
hi. thanks for the question .the clicking sound is something caught, in water pump. the rubber smell is the belt . pull washer away from the wall. small door at the back left corner ,remove pump on the floor. remove 3 3/8 bolts remove. replace . belt underneath washer . replace thanks the appliance doc please rate me
Aug 17, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Dead mav6000
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine, parts are not that expensive, 50-80for bearing kit, here is my site on how to do it http://maytagwasherrepair.googlepages.com/index.html
Mar 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
303 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
