Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Reset I still have the problem of the waste ink pad nearly full. So how can I reset this. I do NOT have resume button for this machine. I have a stop/reset at the bottom left side
    Problem Solver:
  • 13 Answers
Do not worry about the pad, it is a sponge that you can take it out gently yourself, wash it and put it back, no soap or squiz it. do not need to open the printer to do it, can take it out from where you replace the ink tanks.
1)Printer on, press Additional Functions, Scan, Copy, Scan
Now you should be in service mode from there for waste ink tank reset it is simalar to what has already been posted
2)Select Test mode which is like the last avalabe selection
3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
The menu will now say EEPRON Clear
Select Ink count which is option (0) and press set
Then press Stop/Reset Followed by the power button and then wait for it to restart.
Posted on Jan 27, 2008
I am getting this message: WASTE NEAR FULL The waste ink tank* (which holds the ink used for print head cleaning) is nearly full. How can I fix it - the model is a Canon PixaMP110
One of these will reset the message. I reset mine about 2 years ago and have had no need to replace or clean the waste pad.
#1
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
#2
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Jul 23, 2011 | Canon Office Equipment & Supplies
I get a message that says "Waste Ink Near Full".
3 choices are available. Take it in for service(expensive), try to clean waste ink pad yourself(messy) or try this reset yourself. It works on many different models and may be your answer.
I have been running my printer for approximately 2 years since resetting mine without a problem.
Mar 21, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Waste ink absorber is full
Hi Good day!!!
Two absorber pads are located on the right side of the printer, under the ink cartridges. With the printer on, lift the top to expose the cartridges. They will automatically move out of the way. You can move them to the left side by hand if the printer is not on. You will probably need a flashlight to see the pads. They each sit in a rubber retainer. The pads can be removed very easily and cleaned. Take the pads out of the retainers with tweezers. They clean up nicely with warm water but you can use something like Simple Green if they are stubborn. It is best to use a spray bottle (on stream) and blast it through the pad until it is white. Sometimes just putting it under a running faucet will do the trick. If there is ink in the rubber retainer after taking the pad out, it can be cleaned up with a paper towel. Put the pads back into the retainers and you have successfully cleaned the ink absorbers. Now you may have to reset the error message so you can get back to printing. This is how to do it.
Following is the procedure to reset the waste ink counter for the Canon Pixma MP150
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 19, 2010 | Canon i850 InkJet Photo Printer
Cannon PIXMA iP3000 (Waste ink absorber full)
The waste ink absorber is a pair of pads at the edges of the ink carriage path near the bottom of the printer. Canon will sell you a new set to replace them if you want to d-i-y. Alternatively, you can just rinse the pads until the water runs clean once you open up the printer. Dry the pads well before reinstalling. You need to take the printer apart from the top and get under the ink carriage.
Once you reinstall the pads, you can reset the counter by:
Pixma IP3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
I hope this helps.
(most inkjets waste ink counters are set to hit their fill point at the expected end-of-life of the printer. Additional failures may happen soon.)
May 21, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Where is the waste ink
You're probably referring to the Waste Ink Tank in a Canon printer. If you've received the Waste Ink Tank nearly full message, there's a workaround.
The waste ink absorber is actually a pad/sponge that absorbs left over ink spray. There's really no precise way to measure the amount of ink these pads hold so when the message first appears, "waste ink absorber is almost full" it's just an estimate.
The workaround for the message is as follows:
Reset ip2000 / 3000
1. Turn off printer
Using the above procedure should clear the message and your printer should function normally afterward. Best of luck and thanks for using Fixya!
Greg
Nov 26, 2009 | Office Equipment & Supplies
Canon ir 2022 - waste toner full message
Reset ip2000 / 3000
1. Turn off printer
Greg
Nov 18, 2009 | Office Equipment & Supplies
Waste Ink Near Full
Try this:
Waste Ink Tank Reset
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Let me know the result.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 08, 2009 | Office Equipment & Supplies
CANON PIXMA ERROR 5800
The waste absorber is full ,Replace the pads
then if you still get the error,you can reset it by following the directions below.
(reset without replacing pads can cause damage)
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by pressing <--- or ---> then OK
3)SET ABS-M LEVEL TO 0
4)OK
Jan 20, 2009 | Canon Pixma MP450 All-In-One InkJet...
Hi!
The printer counts every single droplet ejected by the print head due to waste ink absorber capacity. When the waste ink counter rise to about 90 % the printer shows message 'Waste Ink Absorber Near Full'; in this stage we can still continue printing by pressing Resume button until waste ink absorber capacity reach 100% and 'Waste Ink Absorber is Full' appears.
To fix this problem you have to reset waste ink counter to 0%. Even though we can just reset waste ink counter without resetting waste ink counter, it strongly recommended that you replace waste ink absorber to prevent ink flooding inside the printer.
To reset waste ink counter, perform the following steps:
  • Plug in power cable
  • While pressing Resume button press and hold Power button (do nor release the buttons)
  • Release Resume button (still hold Power button)
  • Press Resume button twice in a row (still hold Power button), after that release both Resume and Power button (then the printer standing bye)
  • Press Resume button 4 times then turn off the printer
In this stage your printer has operated as usual.
Regards,
Nov 19, 2008 | Canon S200X Ink-Jet InkJet Printer
Waste ink tank full..error 5B00
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Waste PAD ink Reseterfor Canon Pixma iP6320D
You need to Remove the ink Cartridge first in order for the code to take effect.
1) Closethe print head cover.
2) While pressing the Stop/Reset button, press the Power button. (Do not release the buttons. TheLED lights in green to indicate that a function is selectable.)
4) While holding the Power button, release the Stop/Reset button. (Do notrelease the Power button.)
5) While holding the Power button, press the Stop/Reset button 2 times,(Canon idle will appear)and then release the Power and Stop/Reset buttons.(Each time the Stop/Reset button is pressed, the LED lights alternately ineither orange or green, starting with 0.
6) When the LED stops blinking and lights in green, press the Stop/Resetbutton 4 times. (Each time the Stop/Reset button is pressed, the LEDlights alternately in either orange or green, starting with orange.)
7) Press the Power button 2 times. ( the '' Canon" appear twice).The LED lights in green, and the selectedfunction is performed. (When the operation completes, the printer returns tothe menu selection mode automatically.)
8) Power off then back on and test.
9) Congrats!!
Prepared By Jeffrey Vicada (EDS- Technical Engineer) Philippines
Dec 03, 2007 | Canon Pixma iP6210D InkJet Photo Printer
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
62 people viewed this question
old marine
old marine
