Question about SanDisk Sansa e250 MP3 Player
Sansa how do i go into recovery mode
  • 1 more comment
  • shru85 Jun 12, 2008
    hi, I cannot enter the recovery mode on the sansa player (E250 V2). I tried pressing the record button and the menu button together to enter the recovery mode, but it doesnt work. My computer is not recognizing the player, but when connected to the PC, my player is charging.
    Please help out!!
  • dx crash7 Dec 31, 2008
    ok my e250 wont even turn on i press
    the power button and all i get is the blue
    ring the blue ring light comes on but
    the screen is still blank its just black
  • dennis6492 May 11, 2010
    it doesnt work the screen doesnt lit or anyting less what oter options do i have?
    Problem Solver:
  • 19 Answers
Plug in the mp3 player, once it turns on, hold the power button until it turns off then switch the hold switch to hold (showing orange) and then hold the REC button on the side until the player turns on with a black screen, saying its in recovery mode.
Posted on Jan 24, 2008
Hold the rec button and press power worked for me, holding the rec button alone didn't do anything.
Posted on May 14, 2008
4 Suggested Answers
mixmaster
  • 626 Answers
SOURCE: After reset my sansa in recovery mode have lost a setting
Update your firmware.
Firmware Update
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Posted on Oct 28, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: need help with recovery mode
Use voluem + method listed below:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
SOURCE: sansa e250 mp3 player
remove ur batery and replace it or download the file archieve.exe and install audible folder.then u can switch on it.
Posted on Jul 03, 2008
Iphone logo moves back and forth, cannot get to Itunes
Try putting your iPhone in recovery mode.
follow the link to see all the information you need.
Succes! How to Put iPhone into Recovery Mode
Oct 08, 2014 | Apple iPhone 3GS Black (16 GB)
Iphone stuck on itunes recovery mode
Your device stucks in DFU mode, you can try some 3rd party ios data recovery tool to exit recovery mode. Follow this guide to have a try DFU Mode How to Enter and Exit DFU Mode of Your iOS Device
Aug 12, 2014 | Apple iPhone 3G
Macbook Air trackpad moving by itself
Boot the computer into recovery mode and see if the track pad is still moving around by itself.
Hold down the OPTION key when turning on the computer, and select the Recovery icon to boot into recovery mode.
Here is a link that will guide you throw it in detail How to Boot Into Lions Recovery Mode
The purpose of booting into recovery mode is to see if the track pad is still acting up. If the track pad is operating normal in recovery mode, then it might indicate an issue with your operating system. If the trackpad is still having issues in recovery mode, it would indicate that your trackpad issue is a hardware issue and it will require you to take it into Apple for further diagnosis.
Hope this helps!
Feb 13, 2014 | Apple MacBook Air
Phone 4s will not shut off, keeps rebooting
You will want to try to put the device into recovery mode and perform a restore. You can follow Apple troubleshooting article HT1808 to walk you through putting the device into recovery mode. NOTE: Check for any backups before you put device into recovery mode as you will not be able to backup once it is in recovery mode. If the device has been jailbroken and recovery mode does not fix the issue the hardware has been damaged by corruption and should be replaced.
Aug 11, 2013 | Apple iPhone 4S
How do i get to recovery mode
Apart from the messy key combination, you can enter into recovery mode with help of android app onto your device. Just download "Quick boot" from Google play store and install it.
Open the downloaded app, you will see 4 options, Reboot, Recovery, Boot-loader, and Power Off. Just tap Recovery and your device will reboot in recovery mode automatically.
Apr 23, 2013 | Computers & Internet
Iphone 4 restrictions passcode recovery
Entering iPhone Recovery mode to bypass the passcode. The ever best and easiest way to enter and exit iPhone recovery mode is to use Tenorshare ReiBoot. It is free tool to put your iPhone into or out of recovery mode with one click.
Mar 30, 2013 | Cell Phones
Help please tell how to exit recovery mode
How to Fix an iPod Touch Stuck in Recovery Mode With a Free Program
An iPod Touch's "Recovery Mode" is for alleviating major operating system issues. Recovery Mode rolls back your iPod's operating system, stripping problematic updates and downloads from the unit. The goal of this total system recovery is to revert the iPod to a stable, usable version. Before you use Recovery Mode, exhaust other troubleshooting methods. In some cases, Recovery Mode is triggered automatically after a failed system update or system restore. When it goes into Recovery Mode automatically, you cannot use your iPod until you complete the recovery process. You can get your iPod Touch out of Recovery Mode using Apple's free iTunes software.
Things You'll Need
-Apple iTunes-USB cable
Instructions
1 Turn on your computer and open iTunes. If you are prompted to download any new iTunes updates, install the updates before proceeding.
2 Plug an iPod USB cable into your computer. Do not plug the other end into your iPod Touch yet.
3 Turn off your iPod Touch. If the iPod Touch is already shut down, skip this step.
4 Press and hold the Home button on your iPod Touch, and plug the other end of the USB cable into your iPod Touch.
5 Release the Home button after you see a white USB icon and the iTunes logo appear on your iPod Touch's screen. At this time, a pop-up should appear on your computer screen, explaining that the software has detected an iPod in Recovery Mode.
6 Click "OK."
7 Click on the iPod Touch from underneath the "Devices" heading on the left-hand side of your screen.
8 Click on the "Home" tab, and then click "Restore." Once it's restored, your iPod Touch goes out of Recovery Mode and you can start using it again. The restoration process takes a few minutes. Do not disconnect your iPod Touch until a prompt appears, letting you know the system restored successfully.
Dec 24, 2011 | Apple iPhone Audio Players & Recorders
Monitor only works in safe mode, how can I do a recovery in safe mode. Recovery in a partition
If your monitor only works in safe mode, try to reinstall your video card driver while in safe mode.
Hope this helps.
May 27, 2011 | Gateway P-6831FX Notebook
Recovery mode
plug the player into a computer that has zen software and it should then come back out of recovery mode , try to stop player playing when you are finished with it so it doesnt keep going to recovery mode
Mar 10, 2008 | Creative Labs Zen Micro MP3 Player
Recovery mode
Recovery mode won't help you unless you have the recovery files to go with it. Most likely you will need to re-install the firmware on to the device. Download this "recovery tool" from the SanDisk website and run it with your device connected in recovery mode. Make sure you select "format" when prompted. Tool is here; http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe Recovery mode - power off device. Slide "hold" switch into hold position. Press and hold "record" button and then connect to PC.(keep record button pressed until after connected to pc) Hope this helps.
Sep 04, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
582 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
