Question about ASUS P4PE-X Motherboard
Asus Mobo Will Not Boot After Memory Upgrade
Hello, ***Thread may be long, but I need help
Hello, --Thread may be long, but I need help
I have an ASUS P4PE-X mobo, - P4 2.66 & 533 FSB, bios version 1007. I recently decided to upgrade the memory from 512meg to 1 gig all PC2700 333 & 2.5v, cas 2.5 sticks. After installing the new mem, XP could not boot up always hanged, and if it did it was very unstable and would crash. After thel install, bios saw the new upgrade and correctly reported 1024, however. When I disable quick boot at cmos, the bios reports memory error. However when I set the cmos option memory Turbo Speed to disable, bios does not report memory error. After that change XP booted correctly but was somewhat unstable about 40%. After running for about 5 hours the computer crashed and it has never started up again. Now there is no bios screen, no beeps, nothing.I tested the memory sticks on friends computer, the work fine,either together or individually.I cleared CMOS removed all cards except Vid - nothing, removed vid - still nothing. However when I remove the all mem sticks, the system realizes it and I get continuous beeps (no ram), when I re install the rams system hangs. Any help will be very much appreciated, I am on week 2 of fighting this.
  • txtim Jan 22, 2008
    Thanks djick989....
    mobo still won't boot with original stick, is there a flaw in the design of this mobo or was it intentionaly designed to be picky on memory? Could the mobo be dead for good, since I used the kingston mem stick?
  • 1,067 Answers
Not right ram gotta use samusng low density sum mobo so picky
Posted on Jan 21, 2008
Amd processor upgrade
The M3N78-em mobo doesn't support AM3 processors. It is an AM2 / AM2+ platform. A wonderful GPU for you would be this.
If you have any other questions please write back in this thread. I will be happy to help you through your computer upgrade.
Jul 06, 2010 | ASUS M4A78T-E Motherboard with AMD Phenom...
Upgrade question on ASUS P5GD1-VM/S mobo
According to the manufacturer it will support P4/celeron 3.6Gz+ procesors. And memory should be Dual channel memory architecture 4 x 184-pin DIMM sockets support max. 4GB DDR 400/333 non-ECC memory. Hope this gets you up and running.
Jan 31, 2009 | ASUS P5GD1-VM Motherboard
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
500GB SATA with SATA to IDE adopter
You have crossed wiring somewhere
Nov 06, 2008 | ASUS P4GE-MX Motherboard
Wont boot up
You could be using the wrong type of memory. Check your mobo specs to see what your mobo is compatible with.
Oct 23, 2008 | ASUS P5RD1-VM Motherboard
Memory Issue
yeah you should upgrade. Windows xp 32bit only support up to 3gb memory. You should upgrade to 64bit.
And your specs? Yeah it can run 64 bit operating systems or if you like, use Windows Vista x86 or x64 with Service Pack 1.
Sep 24, 2008 | Microsoft Windows XP Professional x64...
Asus P5N-E SLI Mobo will not boot or post.
Hi bart, please re-check you're memory. See page 1-17 in you're user manual. (Read everything)!
You're Asus board can not use 184-pin DDR DIMM's.
Also check the QVL list for supported memory page's 1-18 & 1-19.
I did not see Corsair on either page.
You're board can only use 240-pin DDR2 memory. Please read the "Notes" at the top of page 1-18.
If everything (Regarding memory) is within the Asus specifications than clear the cmos/bios & re-boot again. If you're system still does not boot than remove one DIMM & try again.
Asus warrants their boards for three years. Call Asus tech at
1-812-282-2787 EST, IL 8:00AM to 5:00PM. The call is on you but the service is free. It's worth every dime.
Good Luck & Kind Regards.
Would you be kind enough to let me know what Asus suggested? (If it comes to that).
May 15, 2008 | ASUS P5NSLI (0610839134670) Motherboard
Processor upgrade for my Asus P4V8X-MX motherboard
ya it has ddr u could beef ram up aint much chip u can get higher in this mobo need new mobo to run quad cores amd ect is am2+ mobo better cheaper ram too get more up to 8 gb 16 sum mobos on new egg
Feb 04, 2008 | ASUS P4V8X-MX Motherboard
I'm sorry to say that I had much the same problem with a RMA'ed mobo from Asus. The one that came back worked for a short time, and then died.
I can't say that Asus is the only one I've had the same problem with, Intel has done the same. But I kinda expected more from Asus. I did not bother again, I just decided to do a mobo/CPU/memory upgrade at Fry's.
Jan 27, 2008 | ASUS P4S800-MX Motherboard
Asus M2N-MX Motherboard 4gb Ram wont work
I had the same problem and ASUS tech support was of no help. I did however find the culpret in the BIOS setup. Go to Advanced, Chipset, NorthBridge Chipset, and Memory Configuration. Set the Bank Interleaving to Disabled and save the settings. Check these settings also while you are there:
Channel Interleaving = Auto
Enable clock to all DIMMS = Disabled
Memory Tristate = Disabled
Memory Hole = Enabled
Unganged Mode = Enabled
Power Down Enable = Enabled
Power Down Mode = Channel
By Wayne F
Dec 19, 2007 | ASUS M2N-MX Motherboard
ASUS P4PE-X Motherboard Logo
414 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
