Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Bissell rug cleaner does not spray - Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
It could actually be something else entirely. Notice the person telling you to replace the belt is a company that sells vacuum belts.
Posted on Jan 11, 2010
  • 701 Answers
That means that the pump belt is worn or stretched and needs to be replaced. Here is a link to the belt you need and the manual which has instructions:
Bissell ProHeat Belt and Manual
Posted on Dec 13, 2009
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
  • 40 Answers
SOURCE: directions for Bissell upright rug shampoo vacuum
Indeed, losing directions can be quite frustrating. Below, I did some research and found a website which has most Bissell Vacuum cleaner manuals and directions online
http://homeappliance.manualsonline.com/manuals/mfg/bissell/bissell_product_list.html?s=gg314159
Hope this helps.
FerrariXP
Posted on Mar 17, 2008
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
  • 10 Answers
SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Posted on Sep 26, 2009
heatman101
  • 43501 Answers
SOURCE: my bissell proheat rug shampooer wont wet carpet at all
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
gfhjdhg
Posted on Sep 30, 2010
Brushes not turning
It could be the belts. They are pretty easy to replace. Check the bottom of this tutorial http://www.diyvacuumrepair.com/carpet-cleaners/how-to-fix-a-bissell-proheat-that-wont-spray/
Feb 28, 2016 | Bissell 2X Proheat 9200 rug cleaner
Proheat2x9200 won't spray
Hi William! Spray is important when trying to clean your carpet. Sorry you're experiencing difficulty. We have a terrific FAQ that'll help with.
Here's the link: http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Oct 24, 2013 | Bissell 2X Proheat 9200 rug cleaner
Bissel pro2 carpet cleaner stopped sraying how to fix
Hey Diane! Sorry you're having difficulty with the spray on your ProHeat 2X. Here's a quick link to troubleshooting steps to assist you.
Jan 15, 2013 | Bissell 2X Proheat 9200 rug cleaner
Bissell pro heat wont spray
Not to be negative but I fixed one Bissell, and it worked for a while then it broke again. My Daughter bought one and it broke on her after using it only 3 times.
buy the rug Doctor or some other brand . That is my advise. Otherwise you will have to keep fixing that one.
Oct 22, 2017 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell proheat 2x rug cleaner wont spray water out on rug when you press button
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
May 09, 2010 | Bissell 8910 ProHeat Clear View Upright...
My bissell proheat rug shampooer wont wet carpet at all
heatman101
gfhjdhg
Jun 26, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Bissell Pro Heat rug cleaner, it runs but no water sprays.
heatman101
578yur
Jun 13, 2009 | Bissell 8910 ProHeat Clear View Upright...
Will not spray
The heater is probally clogged. Remove the upper housing and locate a rectagular shaped object in the middle of machine. Remove six bottom screws and clean with stiff brush, clear all lines then run 3 tanks of hot water trhought he system to clear it.
Apr 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Lost manual for bissell pro2X rug cleaner can I get inst. on line?
hi,
Just recently purchased proheat 2x rug cleaner ,miss placed my manual and can't get the water sucked up . Please Help
Thanks
Jun 26, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
314 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
