Question about Kenmore 63932 Electric Dryer
Clothes still damp
We had a guy come and clean the vent - IT IS NOT THAT. The air is coming out very hard and hot from the dryer when you take off the line in the back. What the heck is going on???
  • morgandameon Jan 21, 2008
    the dryer is hot so how could it be the thermostat? The air is coming out the back forcefully so that isn't it. Do you think it is still in the wall then - I will have to call back the flue guy who cleaned it out.
    okay, but the clothes in the dryer are really hot after a load, just still really wet.
  • 770 Answers
The problem you maybe having may still be in your venting a couple of things to check are is the size of the vent should be 4" round also the lenght of the vent if over 10' and alot of elbows it maybe too long of a run but the real test is to run a load with the vent off the back sure you get a liitle extra heat in the house but if it dries ok you found your problem if it still does not work then you could have a bad cycling thermostat try that and let me know
Posted on Jan 21, 2008
  • Gary Davd
    Gary Davd Jan 21, 2008
    what i said was to run a load without the vent on to see if it drys normally.. if it does the problem is in your venting going outside.. if not then there could be a bad cycling stat. you maybe feeling hot air but it for how long ????? if the thermostat is short cycling it maybe turning the heating element off too soon run the load without the vent first and see what happens..
  • Gary Davd
    Gary Davd Jan 22, 2008
    When clothes are wet and really hot is is from poor air circulation if your vent is clear you may need to delint your dryer which involves breaking down the dryer and shop vac out all the lint and builtup in the unit and blower wheel
    Sorry I can be anymore help to you at least i tried
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
Problem drying clothes
This is the classic symptom of "poor air flow". Another symptom you didn't mention (but I bet is happening) is that the top of the dryer gets VERY hot. OK, don't move your dryer yet... get a flashlight and look behind there. See the flexible vent connecting the dryer to the wall? It must have SMOOTH, FLOWING turns. No crushing allowed. If it's crushed/pinched, you found the problem. It's "choking" off the air flow... not allowing the hot air to escape and containing all of it in the dryer cabinet. If this is the problem, pull the dryer away from the wall about 8" and make sure the vent isn't pinched off anymore. Leave your dryer this far out, it'll ensure that this doesn't happen again. If the flexible vent is OK, there is a blockage in your house's internal dryer duct work somewhere. Turn the dryer on and go outside to where the exhaust is. Check air flow. Check the exhaust vent for debris (I've seen birds build nests in the outside exhaust, incubates the eggs...but your clothes won't get dry!). If your dryer location and the exhaust location are quite a distance (20' or more) from each other, you should hire a professional to come out and thoroughly clean it out for you. In this case, you should have this done once a year as part of routine Home maintenance. To test and verify my solution to this, you can remove the dryer vent from the wall and cover the end of it with a pair of old pantie hose. Then run the dryer as usual (the pantie hose will act as a secondary lint trap). You'll see that the dryer will be happy again and the clothes will dry in no time at all.
Aug 21, 2007 | Whirlpool GGW9200L Gas Dryer
Dryer runs fine does not dry proper run 2 or 3 times and still damp clothes vent was not clogged pl,ease help
this website is very helpful, I would disconnect vent tube and dry a load of clothes, if they dry then my vent tube is restricted or too long. If it does not then my dryer needs to be cleaned out on the inside from the lint trap down. I hope this helps Tim
Nov 29, 2010 | Whirlpool WED5500S Electric Dryer
The dryer does get hot but takes a very long time to dry a normal load of clothes. What I noticed is that the top right hand corner of the dryer gets scalding hot during the cycle. It worked fine before I...
It sound like you have a venting problem. The air from the dryer is probably restricted by either a clogged exhaust hose or duct work in house or a stuck vent flap where air blows to the outside. If your vent goes straight up to the roof, something may be blocking the exit or the whole line may be clogged. Also check for a kinked flex hose that attaches to the dryer. If blockage is in wall of house, there are vent cleaning companies that can clean out the line.
Feb 04, 2010 | Kenmore 84052 Dryer
Kenmore 90 series dryer leaves clothes damp. The dryer gets hot, but after almost 2 hours a large load is still damp. Happens on both auto sensing & timed dry. Checked insides & all is clear -...
Sounds like a venting problem at the house pipe.
Make sure the house venting pipe is completely clean and vent hood just outside is free of any blockages.
If all that is cleaned I would check all working thermostats and high limit thermostat as well.
Sep 01, 2009 | Kenmore Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Clothes still damp
have you checked the dryer vent,wall vent lint trap for cloggs,if clogged it will hold the damp hot air in the dryer much longer and add to your drying time-mike
May 29, 2009 | Dryers
Dryer not drying clothes
Make sure that the flex hose going out from the dryer is not blocked. You should check it from both the back of the dryer and all the way to wear it vents outside. It could also be the thermostat, which is cheaper to replace than buying a new dryer.
Sep 08, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Clothes Hot but damp, water out of vent
Is this a combo washer/dryer in 1 unit? water shoud not come out if it is just a dryer. Your air coming out of the back vent hose should be hot. If your clothes comes out of your WASHER damp (more than normal) then your washer is not spin drying good enough. (worn belt, clogged drainage system).
Jan 09, 2007 | LG DLE2532W Electric Dryer
Dryer seems to work, but clothes end up damp?
Corwyn, looks like the problem you are having is not with the dryer. The vent line is probably clogged up, which caused the moisture to stay inside the dryer. To make sure this is a vent problem, you can disconnect the vent hose behind the dryer and run it for one load with it disconnected. If it runs fine, then the vent line needs cleaning. Usually it needs special equipment and is very hard to do yourself. It would cost you around $90 to get a professional out to do it for you. back.
Dec 19, 2006 | Whirlpool LER6636PW Electric Dryer
Kenmore 63932 Electric Dryer Logo
205 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
