Question about Hobart A200 Stand Mixer
Old hobart s-30 mixer oil
I have an old hobart s-30 mixer, it works fine but , there is no oil showing in the little window??? should there be? and what kind of oil should i use ?
  • houseofpizza Feb 01, 2009
    Hobart H600T
    Needs oil change. What weight? and how much does it take?
    Thanks
Hobart 30qt mixers have no sight glass also they use grease not oil!
The problem is the grease breaks down after heavy use thats why Hobart wants you to service yearly.
Posted on Jan 30, 2008
  • 640 Answers
Man you got an oldie but goodie mixer!im a hobart service tech for 8 years and have only seen about two dozen,unfortuantly parts for these units are exhuasted.as for the sight glass they do become cloudy over time and you cant determine the oil level.use a heavy gear case oil.the only way of telling is to drain the oil or if the unit is loud you should probably cange the oil.
Posted on Jan 21, 2008
HOW OLD IS MY MIXER
The Hobart A-200 is an 80's product. These first came on the market around 1985. There is no way to date the one you have without examining it.
The best estimate is 25-30 years old.
Sep 22, 2015 | Hobart A200 Stand Mixer
What oil should I use for the Hobart Mixer P660?
A good standard 90 wt oil is what is ok for the gearcase. This is an old email from a hobart service tech and they recomend a special oil ordered from them. So you can decide which you want to use. "EXXON SPARTAN EP-150 (6 oz)" in the M802 planetary. Hobart part #102973-13. This IS NOT a food grade oil. If you mixer is leaking you shouldhave it serviced. Service, parts , lubricants and information canbe obtained by contacting your local Hobartoffice in Pittsburgh@ (412) 788-5380. Steve Davis Field Engineer -
Sep 23, 2011 | Hobart P660 Stand Mixer
How to change oil in 20 quart hobart mixer and the type of oil
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
Dec 20, 2009 | Hobart H600 Stand Mixer
I have a very old kitchenaid that stopped working. It's at least 30 years old, still have the "Hobart" name on it. Any ideas where I can bring it to get fixed?
Hi, FIGSONWHEELS, Sorry, but you don’t have a KitchenAid mixer. You have a Hobart mixer, which is another brand altogether.
You might try the Hobart website and seek assistance directly through them. They tend to be very close lipped about releasing information on how to fix their mixers by yourself, as they have a whole business unit that services their industrial/commercial floor mixers. You can click on this link for the Hobart Service website: http://www.hobartservice.com/Locations/
I hope this will at least get you pointed in the right direction. Good luck, Howard – Burke, VA
If this solution was helpful, please rate it, thanks! - hslincoln
Dec 13, 2009 | Food Mixers
Have an old hobart 140 mixer and i want to chang oil what kind of oil do i use
you need to replace it with a "FOOD-GRADE" mineral oil or FOOD-GRADE white lithium grease, you can get this from "Lubri-Plate" at their web-site
Nov 18, 2009 | Hobart D300 Stand Mixer
Hobart mixers A120 & A120T.. has an oil leak. Need Seal kit/repair parts info and type of oil to replace.
You need to take the old grease out and replace it with new and then replace the oil seal
by the way it is messsssssy
Jul 17, 2009 | Hobart A200 Stand Mixer
Age of my a-200 mixer
if it has a spec.# instead of a ml.#it would have to be at least 25-30 yrs. old
Jul 04, 2009 | Hobart A200 Stand Mixer
Hobart m-802 mixer won't start up
call Hobart for the correct oil any way and an elcetrican will just add more problems for yoy
May 30, 2009 | Hobart A200 Stand Mixer
Old man needs help with hobart 30 q mixer
it has to be torn apart to change grease and it is grease do not put oil in it. but it all is done from top under cover is the top of transmision the round cover comes of and all shafts need to be removed and I sugest a new main shaft seal and hub seal while your at it.
Nov 29, 2008 | Hobart A200 Stand Mixer
Servicing Hobart A-200
these mixers dont use oil,they use grease.you will have to open the transmission to change the grease.any ? let me know im a hobart tech.
Jan 25, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
540 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
