Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Lack of use is not the cause of the leaking of oil from my KitchenAid Artisan. It is 7 years old. It seems I need to get into my mixer and repack a few gaskets. It is not due to lack of use. Last weekend, I made a cake, two quick breads, and then potato bread. It began leaking after the last item. This weekend I made two quick breads and then cookie dough. It began a light stream/trickle after the first recipe. I thought maybe it overheated and the viscosity of the oil began to break down? Can this be repaired at home?
  • 235 Answers
Hi BESTATTI2UD. Your KA mixer’s internal gears are factory packed with enough grease to last a lifetime, whatever that means? Depending on the age of your mixer (7 years), where it was stored and how heavily it’s been used; these factors all will eventually cause the grease’s base oil to separate from its additives, with the resultant oil seeping from openings beyond the gasket down the agitator shaft, which is the situation you are experiencing now with your mixer. Gravity can be very insidious. To answer your primary question after 7 years it’s time for some TLC maintenance on you mixer, and yes, you can fix this yourself at home.
The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM150P, and select this file, KSM150PSWH0.pdf (773.44 KB),
under Parts List (61) (check to see it matches your mixer model).
Turn to pages 4 & 5, titled: Case, Gearing and Planetary Unit, which provides an exploded view for the disassembly and reassembly of your mixer, along with all the parts. You may want to order Part #19, transmission case gasket, and some food-grade grease for starters. Once apart you can check for any other unseemly wear and tear on the gears, etc. It can be messy but very gratifying.
When you re-grease your transmission I recommend using a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call). As far as parts go, here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should be search for ‘food grade grease’ if you start digging into the transmission. Prices can vary widely between vendors, so do your comparison shopping.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers are different models than yours, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! - hslincoln
Posted on Dec 13, 2009
Leaking oil in the point of the mixer
You can try running the mixer at high speed for a few minutes to try to blend the grease in the gearcase. If this does not work, then cleaning out the old grease and repacking with new is the solution.
Assuming you have a 4.5 quart tilt head, a 5 quart lift bowl (not the professional series), or an Artisan, the Service Manual you need is at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Jan 02, 2015 | Food Mixers
Mixer leaking oil is it possible some got into my cookie batter
It's pretty impossible to say for sure without having been there to witness it, but it seems possible that it happened. Some mechanical oils and greases are all-natural and wouldn't harm you if you ate a little of them, but that's not something that KitchenAid would ever tell you. As frustrating as it is, I for one would probably choose the safe route and make a new batch.
Dec 22, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen aid mixer repair locationsi
Leaking oil is caused by the grease in the gear box separating. This often happens when the mixer is not used much and the grease is not kept mixed by the moving gears. The solution is two-fold. First run the machine more frequently. Second is to open the head and replace the old grease with an approved food-grade grease (6 oz. is the right amount). KitchenAid grease can be found online and at Ebay. The Service Manual can be found at:
While the Artisan series is not specifically referenced, the procedures are the same.
You can also take the mixer and manual to a competent repair person.
Jul 13, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Stand mixer leaking oil
Your gearbox grease is breaking down, time to repack it with some new stuff.
Nov 30, 2012 | KitchenAid KSM150PS Artisan Series Stand...
My Kitchenaid Artisan Mixer is leaking oil or grease
Your kitchenaid mixer is meant to leak a tiny amount of oil around the rim of the planetary gear on the front of the machine. This is just a means of lubrication. If however you are getting alot of oil coming out of the sides of the unit, the transmission gasket may be worn or broken if this is the case it will have to be replaced. part number for the gasket is 4162324. If your getting alot of oil from the center of the unit this could indicate worn or broken seals. there are 4 located inside the unit, and would need to be dismantled in order to replace. part number for all four is 3180163. If you are leaking alot of oil or grease continued use of the mixer might cause it damage. Hope this helps
Thanks
Nov 03, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen aid mixer leaking yellow oil is it repairable it still tu
It can be. This may require replaing the plate that the shaft comes through, since there is now enough play to allow the grease that is in the nead to leak through. You can find the parts online, but be ware, it involves tapping out pins and undoing many screws. Manuals are available online at Kitchenaid.com
Jan 24, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Oil Leak
There are screws under that metallic ring on the mixer head. Gently remove the metalic ring by pushing down on its edge with a screwdriver. Once the ring is removed the screws are exposed. Tighten each one and then again to make sure they are snug. If this doesn't work, you need a new grease gasket. Good luck.
Jan 04, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid wobbles when mixing
Do not store or transport the mixer on its side ever. Always upright. The grease in the gearbox should even out eventually. Try sitting on it when it wobbles. At least yours works.
Dec 26, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Leaking oil
thats the planetary seal thats leaking.the seal is cheap its the labor that may be costly.is it just a nuisance leak or a lot?you dont want any oil to get in your mix.
Aug 16, 2007 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
312 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
