Question about Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ Bottom Freezer Refrigerator
THERE IS SOUND OF MOTOR RUNNING AS USUAL BUT I AFRAID THE REFRIGATION SECTION MAY NOT WORK PROPERLY, SINCE THE IS NO COLD AIR FLOW INSIDE. THE FREEZER SECTION SEEMS TO BE WORKING WELL.
  • 4,070 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Posted on Dec 13, 2009
Freezer works but refrigerator doesn't get cold
There is a flapper mechanism in the freezer that directs the flow of cold freezer air into refrig compartment. If it is not working properly and is in the closed position the refrigerator will be much warmer than normal. Also make sure that the evaporator fan in freezer is running - it pushes the air out.
Sep 02, 2015 | Dometic Refrigerators
I have model number PDE18LZRBB. Freezer works fine; refrigerator section will not cool properly.
Your problem is usually caused by poor air circulation. The only way the refrig section gets cold is from the fan in the freezer blowing cold air into the refrig section. The fan should be behind the back wall of the freezer and should be running at the same time the complete refrigerator is running. No fan run---no cold in the fresh food section.
Apr 01, 2015 | GE Refrigerators
Have ge gt mdl# gts22jbpbrww. the freezer is cold but the refrig is not getting cold. I took apart the cover showing me the freezer fan and it is not working could this be why the refrig is not getting...
Yes, if the fan is not forcing the cold air from the freezer section to the refrigerator section, then it will be warmer than it should be. Also check to make sure that the cooling tubes aren't blocked with frost/ice. If you put a hair dryer to the cooling tube openings you should feel the air flow on the other side.
Sep 06, 2011 | GE Refrigeration 21.8 Cu. Ft. Top-Freezer...
Refrig is not cooling. freezer cold but not freezing. Already cleaned condensor
several potential problems
1) evap fan motor isnt running to circulate air into fresh food side
2) it isnt defrosting (do ya see what looks like snow on back of freezer)
3)depending on brand or model their is a damper which isnt opening to allow air flow into fresh food section
those are 3 possibilities all of which involve the air flow into the freshfood side to be blocked off
Jul 18, 2011 | Refrigerators
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Frezzer works refig not getting cold
sounds like it is a fan issue - there is a fan the blows the cold air from the freezer section in to the refrig section, stick ur head in the refrig section and see if you hear a fan running - you probably wont - you will actually probably start to notice that the freezer section is getting really really cold, like to the point of a deep freeze... the good news is that as long as the freezer section is cold your compressor is still working, so this will not be all that spendy to fix...
Nov 04, 2009 | Refrigerators
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Vegetable section too cold, freezing the vegetables
if youd like you can remove the affected crisper, locate the "adjustment slidelever" and remove it, behind there youll find a hole(which is what youve been restricting to lessen the cold air flow.) try wadding up a ball of perma-gum, window sealer, some sorta plug forthe hole, its not nessecary for function of refrig, only to make the crispers colder, but usually too cold. blocking of fthe hole willl make the crispers only as cold as rest of refrig
Mar 23, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ Bottom Freezer Refrigerator Logo
61 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
