Question about LG L1932TQ LCD Monitor
I shut down my computer at night. When I come back the next morning the computer is off and the monitor is in standby with an orange power light (so far so good). When I turn the computer on, the monitor shuts off and I can't get it to turn back on. The first 2 times this happened I was able to unplug the monitor power cable and plug it back in and it worked. However, this won't solve the issue anymore. The only things that happens now when I unplug the power cable and plug it back in is the blue power light blinks once, but the monitor won't power on. Any help would be greatly appreciated!
  • 24 Answers
My monitor did that and it was bad i had to buy a new one. Besy buy 19" is fairly prices. and know i always run two monitors at a time
Posted on Dec 13, 2009
    Sergeant:
  • 193 Answers
That blue light show and error or faulty problem internally or there a problem with in the connection or computer but first check the makers website or manual for troubleshooting.
SOURCE:
Last night I cut my computer off and it froze on the shutting down screen so I held down the power button and it cut off. Now when I cut it on the light on the monitor is orange. It's Gateway 817GM. Help?
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Jun 27, 2014 | Computers & Internet
Proper shut down
Hi doodu13appa,
Nothing beats a complete "Shut Down" through the Start menu in the lower left-hand corner of your Windows screen. This allows all open windows to be properly closed, with current data saved, memory and cache cleared. This is like going to bed at night with nothing on your mind, sleeping soundly, and waking up refreshed in the morning.
Then, when the computer is powered up the next time, it will be operating at its optimum performance levels without being "bogged" down with excessive leftover garbage from previous sessions. There's nothing wrong with powering your laptop, or desktop, down by clicking the power button and letting it go into standby, sleep, or hibernate mode, much of the time. It leaves you with a quick-startup the next time you are ready to use your computer, and most of your open programs will still be running in the background. Clicking on your logon will have your right back where you last left off.
Sep 19, 2010 | Computers & Internet
HPvs17x power flicker on/off no image, 3-10min after image ok!
More likely to have failing power supply problem due to bad caps, look for caps with bulging top first and post back what you see inside, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 02, 2010 | Computers & Internet
Standby light is on but will not power,just keeps flashing up power on then go back to standby.
Try disconnecting everything from the Denon including the power. Leave it off all night. Next morning plug in the power only and see if it will come up ok. Then power down (into standby), connect the other stuff and power on.
Feb 10, 2010 | Denon DVD-2500BTCI Blu-Ray Player
Power Light Blinks Orange on Gateway PC
go to the screen saver and click on monitor power then change the power schemes to adjust, and select standy into never...
Jun 17, 2009 | Computers & Internet
I have LCD Benq 17" monitor that suddenly refuses to power up!
that shouldn't have messed up your monitor at all. It sound slike it needs to be reset. Unplug the monitor for at least 5 minutes. Then plug it in and power it back on.It may be stuck in a standby mode.
Jun 03, 2009 | BenQ FP731 17" LCD Monitor
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
Monitor in sleep mode
This problem could be caused by windows or the monitor .You need to hook up your monitor to another computer and see if you get the same response. If you do check and see in the owners manual if there is a control for power management.Find the control and try to adjust it, or turn it off. If all this does not work than you need to take the monitor in for servicing. If the monitor works,you may have a problem with the computer bios or windows itself. Check all power management controls in the bios and window settings and see if you can find the problem.Check the Microsoft website for this problem with your operating system and a solution. Hope this helps.
Apr 08, 2009 | HP w1907 LCD Monitor
When I boot up the screen is all colors and lines
It sounds to me like your cable is loose to the lcd or the video card is not properly 100 percent seeded into the mother board. Prolly the cable in one way or the other, perhaps bad cable.
Nov 21, 2008 | Toshiba Satellite A215-S7422 Notebook
LG L1932TQ LCD Monitor Logo
206 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
