Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Perfect sound all all canons stopped working
I changed the blue canon coolant & turned it on . It was working but when I went to adjust the focus & flyback voltage it stopped & wont come back on.
  • 566 Answers
Hi The14u.
I was reading your problem and it sounds like you may have overdriven one or more of your tubes with the "screen" voltages adjusts.
That could be the cause of your shutdown.
I`d like you to try something;
Unplug the set for 5 mins or so and in the mean time go to the focus/screens block and turn down completely the screens controls and pre-adjust the focus to about the half way point.
Now turn the set back on and(if it does) adjust the screens voltages one by one,
They shouldn`t have to be much higher than the halfway point again, next adjust your focus. Hope this will help
Let me know how it goes and do not accept or rate this suggestion until the problem is cleared.
Posted on Dec 13, 2009
Canon rebel T3 focus problems
in manual mode, will not try to focus itself, my be the manual auto switch is faulty, or the focus related mechanism not rotating the lens, open the lens carefully check the focus motor and gear set (engine is the technical term)
Sep 01, 2017 | Canon Rebel XT / EOS 350D Digital Camera
I have a canon 100mm macro EF 2.8 lens. When I attached it today to my camera (EOS 400d) it will not auto focus correctly. The working sound it makes is even a different sound to the normal focusing...
Your 100mm lens autofocus not working.it may be due to autofocus flex cable inside the lens damaged. It is replaceable part. You may have to contact service technician. However when you switch to manual mode it should focus & click. Try it.
Sep 29, 2017 | Canon 75-300mm f/4-5.6 III USM EF Lens
I replaced the crt coolant in my 62 inch phillips rear projection tv and the green and red are perfect but the blue is still out of focus when I go to the convergence the cross is perfect but the blue is...
hi,
try to change the crt base socket of blue gun and then try. i will suggest if you replace the base socket change all the three at the same time.
crt base
ok
Jan 20, 2011 | Televison & Video
My Canon powershot A1100 IS is not focusing at all. The lens extends when turned on, but when it tries to focus (when set to "Auto"), I hear a clicking sound, as if the motor is trying to adjust the lens,...
The focusing gear on that motor is stripped and the lens cannot focus. Not cost effective to repair. Canon will charge small fortune for the part and then the LABOR. Workiing on those small cameras is one royal PIA and labor intensive.
Sep 02, 2017 | Canon PowerShot A1100 IS Digital Camera
Brand new Canon EOS Rebel XS. Suddenly, image in the view finder is blurry. Auto focus seems to be working, and pictures are coming out fine. But sometimes, the autofocus focuses on the wrong thing, and so...
Next to the viewfinder ther is a diopter adjustment so you can change the focus in the viewfinder. this is so if you need glasses the camera can be set for you. Start by focusing the camera on something, then slide to turn the diopter adjustment until it looks sharp and try not to bump it.
Jun 21, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Canon camera SX10 IS doesnt turn on
this is a dead battery issue. the batteries were probably already discharged.
Jan 25, 2010 | Canon PowerShot SX10 IS Digital Camera
AKAI PT5598HD - I HAVE REPLACED THE CONVERGENCE BOARD AND PICTURE AND SOUND ARE "ON" BUT "PERFECT FOCUS" WILL NOT BRING BLUE INTO FOCUS. "PF" STOPS AT 37% - RED AND GREEN PATTERS ARE SHARP BUT BLUE IS...
Most of these sets have a SCREEN/FOCUS block---usually all black with 6 controls----you need to look close at it as one row of 3 will be screen controls---don't touch those----the other 3 will be FOCUS- MARKED in little letters will be r,g,b(red,green blue). TWO ways to adjust the focus: 1. carefully locate the blue focus control and adjust to see if blue will improve in focus. 2. each of the 3 large lens where the picture comes out have a wing nut and a slot--you can loosen the nut and turn the lens---usually best focus that way is if the part that turns is in the middle of the available area to move it.
I should point out that all projection sets intentionally de focus the blue--the lines if blue should be clear but never as perfect as green or red--this is normal.
I do this here for free so if this has been helpful give me a vote here.
if you need direct help:
etower.766@netzero.net
Aug 20, 2009 | Akai PT5598HD 55" Rear Projection...
Vx 2000 lens out of focus and memory stick reader problems
it needs to be sent in to sony i work for canon and have dropped cameras before and they went out of focus it needs to be adjusted by a sony tech they have special equipment to do that, i know on canon its alot of work to adjust one and the memory stick part has to be broke sorry.
Nov 17, 2007 | Sony DCR-VX2000 Mini DV Digital Camcorder
Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
Feb 13, 2007 | Canon PowerShot A75 Digital Camera
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
