Question about Sharp Audio Players & Recorders
My 5 disc player rotates trays and the CD spins but nothing plays,there is a click and then it rotates to the next tray like it is not recognizing any CD
  • fireoop Dec 13, 2009
    Tried it after cleaning and then sitting overnight - began to play then went back to not playing again
    CD is not being recognized or something with Sharp CMS R500 AV 5 CD changer. Disc will spin but just clicks - have tried cleaning.
    Top Expert:
  • Sharp Master
  • 80,339 Answers
I would suspect that the laser is defective that reads the CD, if it doesn't read the CD then the logic circuit thinks that there is no CD loaded in the tray and it moves to the next tray and tries to read that one and so on in a continious loop, you can't buy the part so u must send it in for service
Posted on Dec 14, 2009
  • Sharp Master
  • 11,800 Answers
The cd's are not recognized because the optical block (the laser and the lens) is dirty, full of dust - open the case of the player, blow most of the dust from the laser and lens using an can of compressed air and finish by GENTLY wiping the lens using a very fine q-tip.
Posted on Dec 13, 2009
  • Azrael SRL Dec 22, 2009
    The clicks are made by the laser head moving in search for the signal. Since it has worked for some time after you cleaned it this means it has a lot of dirt inside - clean thoroughly absolutely everything inside the case.
Is there an easy fix to the problem given in the details section below?
No there will not be a easy fix for this. You can keep putting up with this the way you have been or buy a new receiver and try to sell this one on craigslist, eBay, etc.
Jan 20, 2016 | Sony CDP-CE375 5-Disc CD Changer
Nakamichi cd cassette player 1 not spinning discs
There's a Music Bank 7-disc player in use in my bedroom these days. Nice unit, but they used to come in for service once in a while- from what I could tell, these units don't 'park' the CD drawers on a soft power off- they simply shut down. When powered up again, they sometimes let the disc last in play slide off the tray & jam the machine. I've had no issues, as long as I always hit stop, wait for it to park, and then shut off. The analog output's sound has been very good (has a coax out as well).
Jul 28, 2012 | Nakamichi Audio Players & Recorders
ITS cd tray is revolving when we press insert button . tray moves inward and it do't select any cd .and tray comes out again. main problem is it do't select any cd
You have a slack loading belt under the tray.The loading action is not being completed because of it.
The Cd lifting mechanism requires more torque than the tray rotating action. If you put your ears close to the tray you will hear a belt slipping sound after the loading tray goes in . If you push the disc motor assembly with your hand from underneath the action sometimes get completed and the cd will start playing. Any way you cannot be doing this all the time, the belt needs changing. Its a set of two belts, one very small for the tray rotation and a thicker/bigger one for loading mechanism.
Mar 11, 2011 | Aiwa Audio Players & Recorders
Tray rotates but CD not recognized, will spin but not play, just clicks and goes to next tray
Laser pickup unit fault. Replace it. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 13, 2009 | Sharp CMS-R450AV Shelf System
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
CD tray wont stay closed
Try using a CD cleaner. Generally this sort of problem occurs due to dust accumulating on the lens. The CD cleaner comes along with a solution.just spray on the CD and allow it to play in the CD drive. Sometimes the problem might even be due to a virus. Check whether your anti-virus is up to date.
Nov 30, 2008 | Integra CDC-3.1 CD Player
Dvd do not loads
Our started doing the same thing about a week after the warranty ran out. It has to do with the alignment of the discs being loaded. here's a work-around that works for us:
Open the tray
Choose which disc you are going to watch and use the Change Disc button to push the selected disc to the back (ie, if you want to view Disc 1, discs 3 and 4 will be visible in the tray).
Look down the center holes of discs 3 and 4... manually move your tray left-or-right to align the holes with the tray.
Push the Direct Play button on the top right of the unit for your disc of choice (Disc 1 using the example above).
hope that helps... I've searched for a while and played around with the unit (with and without the cover on) trying to figure out a way to re-align the tray, but no luck.
--JeD
Aug 20, 2008 | Samsung HT-WP38 System
Cd player shuffles through all discs, but won't play
contact Durabrand at 1-800-252-6123 or Venturer Electronic
203 Eggert Rd,Bufflao New York 14215-0248
Dec 23, 2007 | Durabrand W600 Shelf System
CD Player tray will not rotate or open or close - no power
my cd player will open and rotates but will NOT play, can anyone help me?
Oct 09, 2007 | Audio Players & Recorders
123 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
