Question about Makita MAC5200 Electric Powered Air Compressors
My Mac5200 compressor was running fine. I took a
My Mac5200 compressor was running fine. I took a break and came back and it builds to 80 psi and hovers there for a long period of time. It will eventually build to around 100 psi but will go no higher and does not shut off. Is there any particular part I should be looking for as a fix?
    Scholar:
  • 169 Answers
Piston rings or valves in the head,,, valves are the most likely one.
Posted on Dec 13, 2009
Makita MAC5200.Brand new.Just broke-in. Pressure goes to 140 PSI and stops.Tries restart at 110 PSI.Motor"Humms"only.Will not restart until pressure below 20PSI.
http://www.toolpartsdirect.com/makita-mac5200-3-0-hp-air-compressor.html
There is a part called an unloader. It reduces the pressure on the compressor when the unit stops at the desired pressure. The actual unloader may be part of number 50 in this diagram.
Dec 18, 2016 | Makita Air Tools & Compressors
Troubleshoot overflow condition
Sounds like worn pressure control valve. I'd replace it.
Mar 04, 2015 | Ingersoll Rand XHP1170FCAT High Pressure...
Won't build top pressure an shut off
It sounds like your pressure switch is not set correctly. It is possible it is set too high for the compressor you have.
Sep 23, 2017 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
Air compressor will not restart after it builds pressure and pressure drops to 80 psi
Make sure the power cord is plugged into an adequate extension cord if one must be used. Never less than 12 gauge wire.
The start/run capacitor may need to be replaced.. If there are any ball check type valves, make sure they are not worn or sticking. they would be on the output of the compressor head itself.
Dec 13, 2011 | Hitachi EC12 Portable Electric 2hp Air...
I have a craftsman oiless air compressor. All tools that I attach have low pressure to start. After I hold the attachment wide open for about 10 seconds, it will eventually break loose and the air flows...
check your hose or couplers for restiction --------- try exchaging with know good ones------- the rubber seal in the female coupler may be the culprit ------------torn// deteriated// comming apart & blocking off air flow....
May 25, 2011 | Craftsman Air Tools & Compressors
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor kicks on then reset trips after short while. only pumps about 20 psi each time i push the reset?
How far are you from the power source. The compressor draws a lot of power, if the extension cord is too long or the wires in it are too thin, the compressor will have run issues.
Have you plugged it in close to the main circuit panel and tried it there.
Feb 01, 2011 | Makita MAC5200 Electric Powered Air...
The compressor starts to surge at 50 psi then blows the breaker took the air cleaner off and checked for obstructions none found .if i put my finger on the air inlet and restrict the intake by half it will...
Hi, my name is John. Welcome to FixYa. Clean your air filter, try running it with out it in place and see what happens, and let me know. Thanks for choosing FixYa....John
Dec 04, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
Compressor runs for a bit and builds about 30 psi
Remove the belt and try and turn the pump by hand if it turns free then you have a bad motor and it will need to be replaced
Apr 20, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Makita MAC5200 Electric Powered Air Compressors Logo
224 people viewed this question
Top Makita Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
