Question about Panasonic PT-52LCX66 Projection Television
My tv turns off for about 15 seconds and turns back on by itself about every 25 minutes.There isn't any indicator lights flashing and i just changed the bulb.
  • 10,865 Answers
There can be several causes for this, few of which you can do anything about. However, a few things to try:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
I hope this helps. Joe
Posted on Mar 31, 2010
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
Problem with Sony Grand Wega TV
This could be due to bad capacitors in the sweep supply, a bad High Voltage block, a bad regulator.
Jul 06, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
When I was watching TV today my Sony Bravia KDL-40V4100 just swutched off by itself. After 15 minutes or so it came back on by itself, I shut it off soon after. Later on today after watching TV for 15...
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 12, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E50A10 50 in. HDTV stays on for 25 - 30 minutes then shuts off by itself power stand by light flashes green and turns back on in about 20 seconds by itself. can you help?
Hi, Lamp of TV getting weaker and requires replacement. This shut off by itself will increase day by day until you put new lamp in TV. Always Buy Sony original lamp and avoid aftermarket/ cheap lamp for TV safety.
Jun 09, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Timer in auto start.
if it is the 2000 rs the manual can be downloaded from scytek.net
1. Turn on ignition.
2. Within 5 seconds, press the valet switch 5 times.
· The parking lights will provide three blinks, indicating that you have entered Programming.
3. Press the valet switch 12 times (engine run time)
· The parking lights will flash each time the valet switch is pressed.
4. Within 5 seconds, press the transmitter button corresponding to the desired time ( left button 15 min, right button 25 min)
· The parking lights will flash to indicate the setting.
1 flash = 15 min
2 flashes = 25 min
5. When you are finished, turn off the ignition to save the changes.
all of this is based on that it is the galaxy 2000rs m,
Nov 19, 2008 | Scytek 2000RS-M Remote Control
Tv turns off
Its the lamp that needs replacing. It will run for a couple of seconds and then it would dim or turn off.
May 27, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Durabrand Television
cold sorters that means needs to sorter it again
Nov 13, 2007 | Durabrand DWT2405 24" TV
TV shuts off
I would suggest that you guys turn the unit off when this happens, unplug the unit for 30 seconds, plug it back in, and see if this helps. If this does not solve your problem, you should call 1-800-448-2244, so a service center in your local area can be found for further assistance.
Nov 08, 2007 | Televison & Video
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Panasonic PT-52LCX66 Projection Television Logo
113 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
