Question about RCA RT2500 System
Size of large caps in a rca rt2500
Can someone tell me the value of the two large black caps in a rca rt2500
    Problem Solver:
  • 7 Answers
They are 12000uf 63v
Posted on Mar 18, 2010
  • John Dio Feb 22, 2013
    but, what's the 3rd pin? is the value split in half? i don't think so. the schematic would help a lot :) there's one cap on each of the 2 rails in the power supply.
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
How come I don't get any sound from my RCA rt2500 audio receiver?
I've owned this receiver since the Summer 2001 and it worked well until the audio became intermittent several years later. Eventually, the unit was ON but all sound was dead. It turns out that there are solder joints that developed tiny solder breaks. These were found in the main power board on the large electrolytic capacitors and on the 7 power tab transistors that share a large square heat sink. Thermal cycling can cause microscopic solder joint breaks over years of use. After I re-soldered the broken joints the unit worked properly and is still in use in 2017. Consult a qualified electronics repair technician for the repair, which can be accessed via the removable panel on the bottom of the cabinet. Of course, be sure the unit is unplugged from AC power before starting your inspection and repair.
Aug 21, 2014 | RCA RT2500 System
My rca rt2500 turns of after thirty minutes of playing
Sound that the power supply section has the fault. Seek tech support.
Jun 04, 2012 | RCA RT2500 System
After unit is on several minutes, sound turns to static, crackling noise. Any ideas
I had this same problem, check the power transistors attached to the heat sink near the large caps, they tend to get cold solder joints after lots of heating and cooling. 15 minutes and good soldering iron will probably make a huge difference. I added extra cooling fins to mine to help dissipate the heat. hopefully wont go bad real soon again. Also check the large caps while your in there, maybe a good time.
Dec 02, 2009 | RCA RT2500 System
RCA RT2500 will not turn on
press and hold power button while unplugging and plugging power supply cord may take a few tries worked for me
Aug 16, 2009 | RCA RT2500 System
Only humming noise from speakers
The humming is probably caused by failing filter capacitors, these are usually quite large, also look for cold solder joints around parts the heat and cool continuously. Please post an update to further troubleshooting, if this doesn't solve the trouble.
Jun 19, 2009 | RCA RT2500 System
6800uf/16v Capacitor?
You can use a higher voltage capacitors without problems its the value of uf that should remain the same. But sometimes you can use a higher uf like a 330uf can be replaced with 470uf but never go lower than the original value on uf and voltage. But you can safely use 6800uf 25v or 35v.
Jul 07, 2008 | RCA RT2500 System
Part numbers
wiil get back to you.
Mar 16, 2008 | RCA 32F531T 32" TV
RCA RT2500 Buzzing Sound - Replace 6800uv 16v caps
I did it. I decided to go ahead with the repair myself. I have never done something like this before but it was easier than I thought. I filed off the old parts and soldered on the new. It works like a charm. Thanks.
Mar 14, 2008 | RCA RT2500 System
No Audio With RCA RT2500
Hey EmperorBob, was reading a short across D119 & D120. pulled (I think it was) C139 and was able to get a good reading across the two diodes. reading a short on the cap (out of circuit). Still poking around. Will let you know if I find anthing else...
Nov 28, 2007 | RCA RT2500 System
RCA RT2500 System Logo
248 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
