Question about Acer Aspire 3000 Notebook
How do I remove the cd drive from my laptop? - Acer Aspire 3000 Notebook
  • Acer Master
  • 3,866 Answers
On the bottom og the laptop and inside there is a screw that is holding it into place so you have to access inside to get at the retainer screw inside..
I hope this was Very helpful
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Dec 13, 2009
Removing cd rom
The optical (CD) drive on your Acer laptop connects to the side of the device and is accessed via the underside of the computer.
If you are having problems with the optical drive on your laptop you should address it as soon as possible, and one thing you may need to do is remove it.
The good news is that even if you aren't particularly tech savvy, you'll find that the process of removing and replacing your optical drive is relatively easy.
Turn your Acer off and remove any power cables that may be attached to the side of the unit. Turn your Acer upside down.
Slide the battery out of its compartment on the underside of the computer.
Locate the circular optical drive retaining screw on the underside of your laptop.
It is located just above the square WiFi compartment in the middle of the computer.
Use your Phillips screwdriver to remove the screw and set it aside.
Grip the optical drive by its edge on the side of the computer and gently pull to remove it from the computer.
Slide a new optical drive into the computer, making sure the disk opening is facing out of the laptop.
Replace the optical drive screw.
http://doube.org/aspireoptical
http://www.insidemylaptop.com/replace-hard-drive-dvd-drive-acer-aspire-3610-laptop/
Replace the CD Drive on an Acer Aspire 5000
The CD drive of the Acer Aspire 5000 is designed like most other laptop optical drives.
The CD drive is on the right-hand side of the computer and is attached with screws from the back of the case.
All you need to complete the task is a screwdriver.
To avoid electric shock or damage to the laptop, always ground your tools by touching them against a metal object like a table leg before using them on the computer.
Turn the Acer Aspire 5000 laptop off.
Unplug the power cord from the electrical outlet. Remove the power cord from the power supply in the side of the laptop.
Flip the laptop over so you are looking at the bottom of the case.
Slide the battery pack off the top of the case.
You'll see the CD drive on the left-hand side of the laptop when you are looking at the bottom of the case.
Unfasten the screws that are holding the CD drive onto the laptop with a screwdriver. Slide the drive out of the case.
Slide the new CD drive into the case and secure it with the screws.
Place the battery pack in the laptop and turn the computer back over so it is sitting on its base. Plug the power cord into the power supply in the side of the laptop.
Plug the other end of the cord into the electrical outlet.
http://www.batterystyle.com/acer-aspire-5000-drive-p-307461.html
Sep 06, 2013 | Acer Aspire 5610-4648 Notebook
How do i change the cd rom on a hp pavilion laptop
Hello Turn off your Pavilion laptop and remove the AC power cord. Slide the battery release lever to the unlocked position and remove the battery.
Read more: How to Remove a CD-ROM Drive From a HP Pavilion Notebook N5425 ' eHow.com http://www.ehow.com/how_6138972_remove-hp-pavilion-notebook-n5425.html#ixzz2BTQ7dMMi
Remove the small Phillips head screw on the bottom of the laptop. This screw is used to secure the optical drive to the laptop case.Grasp the front of the CD-ROM drive and carefully slide it out of the bay. Slide the replacement drive into the bay and secure it with the Phillips head screw. Then replace the battery, connect the AC power and turn the laptop on.
Good luck
Nov 03, 2012 | Computers & Internet
How to remove cd/dvd drive on a acer aspire 5003WMLi
Turn the laptop over, on the bottom you will find a screw about 5-6 inches in from the cd-rom drive. The screw will have a little symbol of a CD next to it. If you remove this screw the cd-rom drive should slide right out. Be sure to do this with the laptop turned off, unplugged and with the battery removed.
Sep 19, 2012 | Acer Aspire 5002 Wlci Zl5 - 5000 Series...
My laptop dont read hard disk drive
Okay, shut down your laptop, turn it up side down, remove laptop battery, remove Cd drive by first unscrewing the CD drive's screw before removing/detaching the Cd drive from the computer.
Turn on your computer without the Cd/drive, allow computer to boot, after a while, shut down computer, fix in back the CD drive and turn the system back on.
By now the system should read the CD drive. If it does not, then I'm afraid some this is wrong with the Drive, but I'm sure it should work.
Take care.
Apr 14, 2010 | HP Compaq Presario C500t Notebook
I want to replace my acer laptop Cd rom , from where can i remove old one
Here are the steps on how to remove your old CD-ROM so you can replece it.
Remove all power sources from the laptop. This should include not only the AC power adapter but also the battery.
Locate and remove the screw that locks the CD-ROM in place. Some laptops may have two screws that serve this function. In addition, many will also have a sliding switch that needs to be moved in order to remove the drive.
Slide the drive out gently. It should easily come out and does not require excessive force.
Replace the defective CD-ROM drive by sliding the new one gently into place in the laptop bay, the same way the old one came out. Again, excessive force should not be applied. The drive will only fit into the bay one way.
Secure the CD-ROM drive in place by replacing the screws that were removed previously. Reconnect all power supplies to the laptop and power it on. If the replacement CD-ROM is the exact same make and model as the previous one, the system will probably recognize it right away. If it is a different make or model it will prompt you to supply the appropriate software and drivers to optimize the use of the new CD-ROM drive.
Jan 22, 2010 | Acer (91.49C37.001) CD-ROM Drive
My laptop ate my disk
The CD drive is secured by a small small screw which is located on the under side of the laptop, it normally has a small picture od a cd next to it, if you remove the screw you can slide out the CD drive.
once you have remover the CD drive you can undo the small screws on either side of the CD drive and open the drive and remove the cd, reverse the steps to put it back in the laptop.
However please take care and be gentle
hope this helps
Dec 21, 2009 | Toshiba Computers & Internet
Need to replace cd player in Compaq persrio 700 how do I do it? no screws in hinge covers?
Laptop off, remove the AC adapter, (Charger), if installed.
Remove the battery. Turn the laptop over so the bottom side is up.
Face the optical drive towards you. (CD drive)
See how there is a rectangular looking panel, on the bottom of the laptop? (Looking at the CD drive, the panel is over the CD drive. Bottom side of laptop)
See the single Philips head screw in the panel, towards the left corner?
Remove it.
Now take a paper clip, and bend it out straight. Make a small U-shape on the end of the straightened out paper clip, so you have something to hang onto.
On the drive tray that comes out of the CD drive, is a small hole. Insert the paper clip straight in.
This is a manual release to open the CD drive tray.
Gives you something to hang onto, to pull the CD drive out.
To install the new cd drive, (Player), just reverse these steps.
[Open drive tray. Slide CD drive in. Replace screw]
Nov 24, 2009 | Compaq Presario 700 470024-192 Notebook
CD stuck inside the laptop, not in the CD/drive
If the CD is just a "copy" that can be re-created, then:
1. power OFF laptop
2. straighten-out on end of a paper clip
3. locate the tiny hole on the CD drive
4. push the stylus (the straightened-out paperclip) STRAIGHT into the hole with a strong push.
5. The stylus may need to be longer or stronger.
This always works...
Sep 04, 2009 | HP G70-250us Notebook
Reboot maah hp for hp dv6405us
Hi Ash,
1. Check the CD drive and remove any CD inside.
2. Remove any USB drive from the USB port.
Your laptop could be configure to start up from CD, USB, or Floppy Drive before the hard disk.
Rgds
S88
Jan 02, 2009 | HP Pavilion DV6405US Laptop
Acer Aspire 3000 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
