Question about GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Microwave: When my wife went to heat a cup of coffee and pressed the "Micro Express" button, the inside light "blew", and then the cooling fan turned on and now won't turn off (over 12 hours ago). The bulb, a 20W halogen was blown, however, I was able to replace from ACE Hardware. I was able to install, however, it still does not light and the fan continues to remain on when I close the door to the microwave. What might be the problem?
  • goldazman Dec 13, 2009
    The water heats VERY well. The inside light still fails to illuminate and the cooling fan continues to run as long as the door remains closed.
    Taran, thank you for the input...the solution would appear to be WAY beyond my area of expertise. I will make sure that an appropriate repair person is called. Appreciate your assistance. Thanks again.
  • 10,515 Answers
I suspect you may have a door switch that has failed closed causing the fan to run. It is unlikely that the unit is actually cooking when the door is closed. You can verify this if you put a glass of water in the oven and close the door for about 2 minutes and then see if the water is hot. I suspect it will not be. Try this and we can proceed from there with a plan of attack.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 13, 2009
  • taran_2005
    taran_2005 Dec 13, 2009
    Thanks for your response!!
    WOW!! Now, we have something to work ON.
    There could be many Reasons, so we need to Diagnose it Properly.
    You need to Open the Oven. We need to Find the Motor of the Oven Fan which would be in the Rear of the machine ( On Most Models ).You'll see on the rear the motor for the fan oven.Near this is the terminals for the fan element.Take the wires off the element and test for continuity.If open circuit you'll need to replace this element.
    Let me know the progress.
    Hope i helped you.
    Note - It is Dangerous to play with Oven, if you are not well versed with Electronics.
  • taran_2005
    Thanks for your Response!!
    Though i am Disappointed that you Gave up. However, that's the Correct Procedure, if you are not Expertise in all this as it would require an Immense Application of Knowledge to Fix this. I never thought it would actually Heat the Water.
    Anyway, we Appreciate your Business and kindly accept the Solution, so that this thread would be Closed.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a blessed day!!
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
GE Advan 120 micro not heating food. Unit runs and turns normal
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 20, 2011 | GE Advantium 120 Convection/Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
How to replace light inside of Advantium 120 oven
I am looking for the same... How to replace the light inside the Advantium 120 oven. Any answers out there?
Jan 04, 2010 | GE Advantium 120 Convection/Microwave Oven
GE dvantium microwave stopped heating cookies on the 30 sec cycle
I have arranged for a GE technician to visit my home this Thursday.
Thanks for the e-mail
Sep 02, 2009 | GE Advantium 120 Convection/Microwave Oven
Replace Microwave Light
Apparently there's a flaw in the design. My light has gone out/ been changed roughly evry 9 months. No longer under warranty and cost to have someone come in and replace is outrageous. Light bulb is located on top of the oven. You need to remove the top to get at it. Looked fairly easy.
Jan 01, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave part of my GE Sensor Convection Microwave doesn't work
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 22, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave is on when you shut the door
I tried all the things on your website. Holding the clear button , unplugging,...
So I went back to the last operation that I was doing when the problem started.
I was using "reheat" so I put a glass of water in the micro turned on reheat 1 serving.
It started and then I hit clear after a few minutes and the problem went away.
Dec 15, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
48 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
