Question about Canon DR-7080C Flatbed Scanner
I am unable to stop the scan from the pc, I have to hit stop on the scanner before it will give me the display screen asking to stop or continue
  • 490 Answers
Try reinstalling scanning software. If one of the DLL files are corrupted, this can happen. Also run Scandisk of your hard drive.
S. Mohan, Chennai, India
Posted on Jan 27, 2008
HP scanner is missing. Unable to scan slide.
The ArcSoft PhotoImaging suite is just to process and scan images, but the printer hardware itself needs hardware drivers, which contain coded instructions to communicate with your CPU.
This is the HP scanning software.
Printer/Scanner hardware should have a driver setup disk that came with it.
If you have this disk:
shut down PC
unplug printer
boot PC
uninstall the current version, if in start>control panel>programs
restart PC
install driver from disk or downloaded driver file for your model.
Regards, Clive.
Nov 21, 2017 | VuPoint Office Equipment & Supplies
At certain periods in time all my pc browsers begin to display a web address that i did not type the address is http/***.yyy.zz i have a hp 625 laptop and my catalyst control center does not start it...
You may have a virus. Scan the PC with a reliable antivirus. If you are unable to download one, get a friend to download one that can be run from a USB stick
Oct 18, 2017 | HEWLETT-PACKARD 625 Tur II P540 Notebook
I have a surround sound Zenith model # ZHX313 (vcr,dvd and turner). I turned on the progressive scanner while in menu but now I can't turn it off. I've tried unplugging and also tried holding down the stop...
It's unlikely that you've broken it - you appear to be using the wrong method for switching it off.
Correct instructions for turning Progressive (P) Scan off:
1. Remove any disc from the unit and close the disc tray.
2. Wait for the "NO DISC" message to appear on the display
3. Press and hold the "STOP" button on the front of the unit for at least 5 seconds then release.
The video output should return to the normal setting and "P/SCAN" should disappear from the display on the front of the player.
If you are still unable to switch P/SCAN off, please post back for further assistance.
Jan 03, 2011 | Zenith ZDX-313 DVD Player / VCR Combo
I am unable to scan. Keep getting the msg "error during scan". It starts the scan and then stop!
Hi, Make sure the scanning arm lock isn't on. This lock is used ifyou are transporting the scanner.
Mar 05, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Problems Scanning
I would delete the twain scanning driver and reinstall, but first disconnect the usb cable from the pc and reconnect after you install the scanning software.
Aug 09, 2009 | HP Officejet 5610 All-In-One InkJet...
Code error ffff:0024
While I am trying to scan the images, I am getting the error Code[ffff:0024] & I am unable to scan anything from Epson 1500 model. While I switch on the scanner, it sounds lot from the scanner for continuous 2 minutes. I couldn't get scanned anything ... please
give me the solution.
Mar 30, 2009 | Acer Scan to Web 3300U Flatbed Scanner
connect after PC start up
May 29, 2008 | Nikon Coolscan IV ED Film Scanner
Scanner to Pc File Size and Volume Problems
Hello We have been having this same problem when scanning Black and White as well. We have just played around and have changed one of our settings that has seemed to solved the problem for now. Try Properties (on scan settings) then more then click on - Detect Page Size - Image Width instead of Guide Plates Hope this works for you to
Jan 18, 2007 | Canon DR-9080C Path-Through Scanner
Scanner will not connect to computer
'Twain' only means 'Technology without an important name', as this is refering to your printer/scanner, i would suggest that you disconnect the printer and remove any driver from Add/Remove programmes. Re-install printer software/driver and re connect printer when prompted and if possible in a different usb port, if that's how it's connected. If the problem persists and the pc is unable to communicate with the printer the fault will lie with the hardware. Hope it's only a driver glitch.
Nov 27, 2006 | HP PSC 1510 All-In-One InkJet Printer
Canon DR-7080C Flatbed Scanner Logo
91 people viewed this question
old marine
old marine
