Question about Sony Playstation 3 (PS3) Console
No video output
I had my ps3 hooked up to a samsung 530 series 40 in HDTV via an HDMI cable at school. when i came home and tried hooking up the ps3 to a tube tv via the 3 cables and nothing shows up. I then tried to hook up the ps3 to the older samsung hdtv that only has 720p capability it did not work. The TV said that this mode was not supported. I dont know what the problem is but i cannot get any vide output from the ps3.
For the ps3 i know why u are not gettin any video. make sure the ps3 is off with the red light showeing in the front then hold down the power button for (i think) 30 sec. u will see the light blink a bunch of times them you might have to re start it but it should show the vedeo againg
Posted on Jan 02, 2010
  • 26 Answers
I duno wether its the same but a 360 has a switch on the side of the connecter connecting to the console on 360 you switch that to normal TV if its saying it does not support it try switch from HDTV to TV or svise sversa
Posted on Dec 13, 2009
Got a PS3 hooked upto a Samsung 40" LCD TV via
I would suggest trying a different TV, and maybe see if you still have any Component or Standard Definition Composite cables to connect the PS3 to the TV and see if it works that way. I would assume you did this when you said you reset the resolution on your PS3, but turn it off, then hold in the power button until it beeps twice in a row. (Just in case) Make sure everything is plugged in twice and your TV is on the right input. If none of that works, there may be something wrong with the graphics adapters on your PS3 in which case you will need to contact Sony about fixing it.
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
Trying to hook-up a PS3 to my Toshiba 32AV500U thru HDMI but I get no picture. I forget how to get to the setup.
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Nov 25, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
I have a HDMI problem with my PS3. I have it
You will need to turn on the PS3 and hook it up with rca so you can access the console menus. Turn it on and get to the main dashboard. 1. Go to Settings -> Display Settings (not video) 2. Select [ Video Output Settings ] 3. Select HDMI 4. Select Resolution 5. Select Screen Size 6. Save the settings 7. Reboot the console. This should resolve the problem. We've seen PS3 consoles that would not reset by performing a hard reset. We were able to resolve this issue through the settings menu though. Let me know if it is still giving you issues.Hank GATpro Repairs
May 14, 2010 | Sony Playstation 3 (PS3) Console
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
We just got a samsung 40 '' lcd tv, model 530 series. We hooked it w/ hdmi and we get a picture but no sound....caleed best buy back and talked for a long time w/ their geek squad, etc. Can you help
Check menu ,Audio my be turned off for HDMI input. Are you using HDMI output from a reciever or combo unit with speaker outputs on it. Those usually have the option to turn off the audio from the HDMI output.
Nov 09, 2009 | Televison & Video
Ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Hooking up bose 321 to my tv
I am about to go through the same process. I have a Bose 321, and am on the verge of getting a HDTV. From what I can figure, the Bose can play a dvd and input it to the HDTV via video and audio output plugs off the back of the Bose to the audio/video input jacks on the back of the new HDTV. I think individual cables will have to be run for each. They usually are red or white, sometimes green or blue. I am sure everyone has seen these in their life. The Bose 321 technology only had what was called an S-Video cable output for the best picture, which is how my current tv gets it's Bose signal, but now HDMI seems to have superceded S-Video. Therein lies an obstacle to be overcome.
Dec 14, 2008 | Bose 321GS Series II System
Optical output, no sound!
Have you selected Optical output from the audio setup screen of the TV? That needs to be selected to transfer TV audio to the optical out of the TV.
Jul 28, 2017 | Sony KDS-60A2000 60" HDTV
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Sony Playstation 3 (PS3) Console Logo
222 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
