Question about Canon EOS 40D Digital Camera
FLASHING BUSY ON LCD PANEL - Canon EOS 40D Digital Camera
Busy signal on LCD panel when down loading images to computer
Posted on Mar 27, 2010
Tip
SELF DIAGNOSING SERVICE MODE AND POWER SUPPLY CIRCUIT
SONY KDL-32EX302 SELF DIAGNOSING SERVICE MODE AND POWER SUPPLY CIRCUIT
SELF DIAGNOSTIC SOFTWARE
The identification of errors within the AZ1-N chassis is triggered in one of two ways :- 1: Busy or 2: Device failure to respond to IIC. In the event of one of these situations arising the software will fist try to release the bus if busy (Failure to do so will report with a continuous flashing LED) and then communicate with each device in turn to establish if a device is faulty. If a device is found to be faulty the relevant device number will be displayed through the LED.
For more check the following link. Use the search tab on the top right corner to find your product .
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Apr 08, 2015 | Sony BRAVIA KDL-32EX301 32" LCD TV - 16:9...
Busy flash picture and 3484 code
When showing busy, most of the time the camera detected an error, but can't find out what is causing the error.
Try the normal "reset" method as follows:
Like a cold boot for a computer, the camera can be "rebooted"
follow the following steps:
Switch of the camera and remove the battery.
Remove the memory card and the lens. (if possible)
Recharge the battery. Wait till the indicator on the charger indicates the battery is fully charged.
Check all contacts, if they are clean and shiny. Contacts (from battery and memory card, only to be cleaned with a dry cloth or cotton swab(s).
Reinsert the battery, reinsert the memory card and re-attach the lens.
Then switch on the camera.
If this does not help, contact a certified Canon repair centre.
Nov 29, 2013 | Canon EOS 400D / Rebel XTi Digital Camera
HP CM 2320 nf MFP keeps saying...... fax line is busy....
I had this problem as well - try the following:
1) Change your rings-to-answer from the default of "1" to "3". This is found in the basic fax setup on the control panel of the printer itself.
This solved the problem for receiving faxes that I was having when testing fax reception by the HP 2320nf from an dedicated fax. The remote fax would fail after repeated rings with a "BUSY" indication in the fax error report it printed. "BUSY" equals either actually "busy" or also it can mean "no answer".
What I found on the 2320nf end was that it had detected an inbound fax but never answered it. The color LCD on it had "fax received" but the device itself appeared hung.
Hope this helps.
Mar 30, 2011 | HP Laserjet CM2320nf All-In-One Color...
My LCD Prostar 816 shows the Speaker light flashing rapidly. When I click on it, it takes me to an Internal Page screen. I can clear out of that, but I get the flashing Speaker light again. This happened...
Aflashinf speaker key indicates that the phone is fowarded.It's either call foward all calls or call foward on busy.
To cancel call forward all calls, press #11 (with the handset in the cradle), then press your own dss button or dial you own extension number (21-36), and press #.
Canceling call foward on busy uses the same steps but uses #12 instead of #11 for the first step.
May 03, 2010 | Samsung Prostar 816 Phone
The metering screen inside the viewfinder keeps flashing BUSY, and the display screen will not show anything.(Canon Rebel XS Digital SLR)
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Mar 01, 2010 | Canon EOS Rebel XSi Digital Camera
D40 "busy" flashing unable to use camera
when down loading images to computer camera displays red flashing busy signal, thus not allowing transfer of images to computer
Jan 10, 2010 | Canon EOS 40D Digital Camera
Camera or software froze up when uploading to computer
The warning about taking the memory card out while it says busy is to prevent corrupting the flash card during a write.  Give you were just reading the data, you should be OK, unless it was deleting the files as they were uploaded.  In any case, you will most likely need to remove the battery.  There may also be a small button battery that will need to be removed as well that is used to maintain the time.  I would turn off the camera, remove the memory card, remove the battery, put the battery back in (without memory card).  If you still have the problem try removing the button battery (I am assuming there should be a holder for one somewhere on the camera body).
Good luck, report back if this works or not.
Apr 25, 2009 | Canon EOS-20D Digital Camera with 17-85mm...
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
Downloading images
I got a same problem so I contacted canon service center. But the technician said there is some problem on my computer or window system, And he recommand me to purchase a multi merory card reader to solve the same.
Dec 30, 2007 | Canon EOS 40D Digital Camera
Canon EOS 40D Digital Camera Logo
434 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
P.J. Ryan
P.J. Ryan
Level 1 Expert
Are you a Canon Camera Expert? Answer questions, earn points and help others
