Question about ViewSonic VE710b 17" Flat Panel LCD Monitor
Blank screen I ve tried different cords, even tried it on my laptop same thing happens it goes black afer a few seconds. Whats wrong with it?
  • ViewSonic Master
  • 3,866 Answers
You probably got yourself a bad backlight or better yet a bad inverter board inside. A lot of experts found if you open this thing up and See any puffed up capacitors replace them as that could also cause this issue. But viewsonics had a issue with a bad capacitor on the power supply board.
I sure hope this information is Very Helpful to you!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Dec 13, 2009
SOURCE:
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
Hi, I have a Princeton LCD17D flat screen monitor and the screen keeps going black after 20 seconds or so. I power up my PC and it turns on then black. If I turn it off and on again the same thing occurs....
It's getting power, it's just not getting signal from the data cable. The cord that connects to the monitor, (not the power) is typically the reason it is going into standby mode. This can also happen if your graphics card driver is missing on your operating system, but you said you tried the monitor on another machine, so I narrowing it down to most likely be the data cable. Try another cable.
Jan 09, 2012 | Computers & Internet
Viewsonic VA1918wm-2 . Screen goes black after 2 to 3 seconds . Have check on other pc , with different VGA cable .....same thing happened.
Sep 29, 2010 | Computers & Internet
Nuvi 255w Turns off (screen goes to black) after a few seconds to a few minutes. No consistency on amount of time. "Turn Off" may be incorrect - screen goes blank/black Sometimes i can immediately turn it...
I have a Garmin 255 myself. And what I have found is, MOST of the time, the problem is that the CHARGER CABLE has an intermittent connection in it! So, when the cable moves, flexes, or stretches, the battery charge STOPS, and the (mostly discharged) battery cannot support the load, so the unit blacks out and turns off. Try S-L-O-W-L-Y moving the cable while connected with the unit on, and watch for evidence of a bad cable! Sometimes a DIRTY (trapezoid- shaped) connector will do the same thing!
May 11, 2017 | Garmin nuvi 255W GPS Receiver
Black blank screen Lenovo 3000 N100
You say the laptop all of a sudden flashed off.
How old is the laptop? You may have suffered one of two things? First of all, if the hard drive will not boot back up, even after using the recovery discs, then that would explain it powering off. I have seen this happen on old desktop hard drives.
Next, try to get the transformer or adapter tested. It may not be putting out enough amperage to run the laptop.
Sep 01, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Laptop Screen goes blank
Are you running on battery or AC? Try using the power cord, remove the battery and see if it continues. I have seen a battery that is on its last legs do some weird things to a computer. Also, check your power management setting. Control panel, power, and set the computer to "always on" just to see if it could be a power management setting. If none of this works, i would back up all your files, and try to reload win xp from scratch.
Jun 23, 2009 | HP Compaq nc6320 Notebook
Blank Laptop Screen
unplug everything from your laptop unplug the power from the laptop close it and turn it over remover the battery open and hold the on button(battery is still removed) for a 10 count, replace the battery
turn on you can plug the power cord if needed the prob. should be fixed
Dec 26, 2008 | Gateway MX6956 Notebook
HTC p3300 often hangs up(black screen, no response to any buttons) when programms with high mem. are running e.g media player
try getting a new battery
charge it while its off!
when the charge LED goes off its done..
Nov 10, 2008 | HTC P3300 Smartphone
Emachines model 780 monitor comes on for one second then goes blank
CANNOT COMPUTE!!!! NEED MORE DATA! Is your monitor the problem or the computer? Try connecting the monitor to another computer. You can also try connecting a laptop with an external video adaptor to the monitor to test it.
Oct 12, 2008 | E-Machines eMachines Desktop PC
ViewSonic VE710b 17" Flat Panel LCD Monitor Logo
124 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
