Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
No yellow color no test printing
No yellow color on output print but new installed cartrige.
  • 526 Answers
Take the cartridge out and look at the area that the sensor checks, and see if you see a lot of ink. it will be clear tube and you should see the ink, if it looks full, then your nozzles that go to the printhead either have air in it or the printhead is clogged up.
try doing up to 5 cleanings, and do a test print, check the nozzle test print everytime, if you do not see an improvement, then most likely the printhead will need to get replaced.
thanks adi
Posted on Dec 13, 2009
Since installing new ink cartrige every time I turn on the printer it prints an alignment page
Hi:
This problem is usually caused by one of the colors in the installed cartrige not printing out on the alignment page. You need to have red, blue and yellow working to get a good alignment. Try removing the cartridge, and wiping the print head with a wet paper towel to try to start the ink flowing. You should see three bands of color ink oozing out the bottom. If not, the cartridge is bad and needs replaced again!
Apr 19, 2010 | HP Photosmart C3150 Printer
Print with single cartrige. I rarely use color. The color cartrige ran dry and nothing will print in b&w until I buy a new color cartrige ( for about $37.50) and install it. HOW DO I BYPASS THIS...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up and prompt you to chose this option, you should be able to tell the printer to print in black .
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | HP Office Equipment & Supplies
ESP9 color prints begin coming out purple like
Use only original ink cartriges, the non original has ink normaly is not for you printer, and you wast your money and damage the printer print-head
Jan 02, 2010 | Office Equipment & Supplies
I replaced both cartriges (Black and Color) and when I print, the yellow color does not print. Even on the test page, the color setion at the bottom is blank where the yellow color block should be printed....
You can dab the bottom of the color cartridge on a damp paper towel, check the streaks left behind, if there is no yellow either there is no yellow in the cartridge or it's just plugged. Dab it a few times on a wet towel, if still no yellow, you need another cartridge.
Dec 22, 2009 | HP DeskJet 932c InkJet Printer
Just had my color cartridge refilled, and reinstalled correctly. However, the printer will not print with the color cartridge in, but will print with the black cartridge only.
your newly installed cartrige which is the colored one is not detected or mybe damage....may i ask if how many times did you refill already your cartrige?refilling a cartrige can cause damage to its circuit i suggest purchase a new colored cartrige and see if it works.
Oct 09, 2009 | HP DeskJet 845c Printer
K 7100/7103 cartridge light blinking
Gill:
I have the same problem as Sheillz (Sept.15, 2009)
I have installed a color ink printer and both black and color lights of cartriges are still blinking and I cannot print anything at all. Not even a test page.
Can anybody help me pls?
Sep 15, 2009 | HP OfficeJet K7100 Photo inkJet Printer
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
HP Photosmart C5180 In Cartriges Empty
uninstall the software and reload it it will mostly fix your problem.
if still the problem presists .
feel free for further assistance.
thanks
Nov 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
The print head on my ink jet is not printing red or yellow in the test program. I've got a i960 printer. Can I get a replacement print head mailed to me or is there a dealer in my local neighbor. Zip =...
The actual print nozzle is typically on the ink cartridge itself, the casing of the print head is little more then a plastic holder for the cartridge. Before you replace the whole thing try this...
  1. Clean the plastic the color cartridge sits in with alcohol and a cotton swab. Especially where the copper makes contact.
  2. Clean the ink from the copper portion of the color cartridge and if possible replace the cartrige temporarily with a new one.
Jul 24, 2008 | Office Equipment & Supplies
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
304 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
