Our minolta 4000 copier machine is 110v supply but we here have 220v supply,kindly tell me what kind of changes i have to do in the supply board of machine to run on 220v supply with out adding additional transfarmer of 220Hv.
  • 1,110 Answers
You would not be able to modify your existing 110v power supply. You would have to have a 220v power supply. This would be nearly impossible to find tho as this machine is now more than 10 years old. I'll see if I can dig up a part number anyway just so you can do some searching.
Posted on Dec 13, 2009
Machine was purchased in USA what is a power supply?
USA standard is 110v. You need a "power adapter" to transform your 220v to 110v. Most US purchased electronics do not have switchable voltage.
Nov 23, 2015 | Office Equipment & Supplies
Change 220v to 110v
You will need a transformer. If the appliance is 220V to start with, you need a step-up tranformer, that is, 110V supply UP to 220V output. The other way round, a step-down transformer.
They are sold at hardware outlets and electronics suppliers like RadioShack.
Feb 13, 2014 | PfaFF Tiptronic 2040
Want to convert hp laserjet 3055 from 110v into 220v
You maybe able to get a new 220v power supply board and swap it out in the printer.
The other way is to get a 110v to 220v step up transformer, make sure the current rating matches or greater than the printer's requirements.
Aug 23, 2012 | HP LaserJet 3055 Flatbed All-in-One...
I have a Minolta EP1054 (in the Middle East) I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared...
was the power on when you depressed the small switch? you mite have damage the lamp in the fuser or the control board. very old machine find the parts and replace them
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 10, 2017 | Konica Minolta DiALTA Di200 Copier
I have a Brother HL2140. It was plugged into a 220v outlet, is there a fuse that can be replaced?
hi. I had the same problem and to fix it you need to take printers right-side cover off. Underneath you'll find a Power Supply Board - hidden under metal cover. Take it out and disconnect two cables from it. Now, I had to replace an fuse 125V 4A and varistor E241AD 83P on the Power Supply Board in mine HL-2140. It works fine now.
Note: I could not find the exact replacements in electronic store so I used:
- fuse: 250V 4A
- varistor: FNR 10K241 (241 is the important number)
Hope it helps.
Oct 15, 2010 | Office Equipment & Supplies
Canon CLC 4000 won't Power Up
hi first of all cheq the required power for clc 4000 is tis 110V AC or 220V AC, secondly verify the outle of power from wall plug may yor machine 220v and you are putting on 110V
thanks
May 11, 2010 | Canon CLC 4000 Copier
Changed power supply from 110v to 220v, now get 50.2 fuser error
The printer will have a 120v fuser, unkess that has been changed for a 220v fuser, it won't get up to temprature on 220v, hence the error message.
It needs a 220v fuser.
May 05, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
Samsung WA71N2, plugged to 220V should be 110V only
chang the board! servise center will charge probably 400sr
Jul 09, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
93 people viewed this question
k24674
jasbo
jasbo
