Question about Mitsubishi WS-48315 48" Rear Projection HDTV-Ready Television
Screen is out of alignment. The picture cuts off a portion of the bottom and top of the screen.
  • cmaclin Dec 13, 2009
    My screen is cropping of the scores of a game at the bottom of the screen and also cropping off the tops of heads at the top fo the screen.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Let me give you a photo and you tell me if your set looks anything like it: let me know what you think.Screen is out of alignment. - fdd8919.jpg
Posted on Dec 13, 2009
SOURCE:
Why does the picture only fill the screen if I zoom in?
Hi Anonymous,
Please use the P SIZE key on the remote control and choose the picture of your liking. It will not be as we are used to see on the conventional Picture Tube TVs.
Dec 04, 2015 | Televison & Video
I got a Zenith Z56DC1D the bulb was replaced and its clean. I have blurry picture and it seems out of alignment there is a large black stripe on bottom and the top of the picture is cut off. How do I fix...
Without seeing a photo it sounds like the picture is letterbox with top and bottom black areas---if not that it sounds like a possible issue with the optical light engine the set uses to project the image on to the screen----most of this is not customer repairable.
Dec 04, 2012 | Zenith Z56DC1D 56" Television
Can't read Subtitles
Look on your TV remote for an aspect button. There are usually several different aspects to choose from.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Sony rear projection kp-51ws510. color alignment
sounds like bad convergence IC---not uncommon on this set-both convergence IC"s need to be replaced and the set adjusted
Aug 07, 2009 | Televison & Video
Heads cut off on the screen
Ocean's Eleven. Best remake movie, I think.
I believe your TV is in "ZOOM" mode for the screen. This will make a 4x3 picture come up closer to fill in the 16x9 screen, but this cuts off the top and the bottom.
Keep pressing the WIDE button on your remote until the picture looks best.
If you have HD channels, the screen mode should be on NORMAL. HD channels will have the 16x9 screen format.
The non-HD channels will have 4x3 screen format. When the screen mode is on NORMAL, you will have the cut off picture on the sides because the 4x3 format will not fill in a 16x9 screen.
May 30, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
are you watching with using time warner cable or an HDTV converter box? because if you are....on the bottom of your cable remote..on mine its the # button..above it says aspect...press that a couple of times and there are different zooms and stuff.
Jul 21, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
Picture cut off
No adjustment needed on these LCD projection. Your problem is in your setup menu. Your default is now is set ZOOM. That is why the bottom of the picture is cutting off. Go to Menu, setup and screen size or something close to that.
Best regards
Circuitcity
Jul 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Solution
You have a bad vertical output IC or a bad capacitor(s) in the vertical driver or output circuits. Not a job for the user to do unless you have the proper tools as well as a service manual. Good Luck
Mar 28, 2007 | Konka K2386U 23" TV
Black screen, small portion of top of picture in view at bottom of screen
your tv has a vertical problem take it to a tech to have them look at it probably on transporting the set to your house it bump around.a look on lose solder could be the problem this could be verified by a tech.good luck.you need the repairman.
Apr 01, 2007 | Sony KP-53HS10 TV
Black screen w/small portion of top of picture showing at bottom of screen
Hello, the problem with your projection TV is in the so called bad soldering in the vertical deflection stage. Please contact a pro in order fot fix the error. If you need more assistance please advice. Arpi
Mar 18, 2007 | Sony KP-57HW40 57" Rear Projection...
Mitsubishi WS-48315 48" Rear Projection HDTV-Ready Television Logo
102 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
