Question about Amana ARB1905C Bottom Freezer Refrigerator
Clumps of ice cubes in back of ice bucket
After we changed the water line filter for the ice maker, we started seeing clumps of ice cubes in the back of the ice bucket. It appears that the rear cubes are slightly melting then refreezing. All the other cubes are fine. Any ideas?
  • 3 more comments
  • Frosty Dave Feb 24, 2008
    How odd that I saw the problem today and then got this reply to my problem! Yes, it appears that it is slightly overfilling and dripping at the rear of the unit. Is there a fix for that? Turn down water pressure?
  • Anonymous Apr 22, 2008
    Ice maker make big clumps of ice and we cant us it.
    what do i do?
  • Frosty Dave Nov 29, 2008
    UPDATE- What happens is that after dumping ice, the unit drips water at the rear of the tray into the bucket. This refreezes causing clumps of ice cubes. I've "leveled" the ice maker but no improvement. So the question now is: Why does it drip water?
  • obicad Mar 01, 2009
    I have the same issue and because the ice clumps up in the rear of the unit near the helix end cap, it cause it to detached from the auger. How do I reinstall the auger to the end cap?
  • Anonymous Mar 12, 2014
    The unit buzzes about every 15 min. or so followed by what sounds like an ice cube dropping, but I have no ice maker.
    President:
  • Amana Master
  • 2,651 Answers
Sounds like your just might not be using enough ice and they are defrosting and clumping together.figure your pulling ice from front of bucket the the backs hardly get used espescially in winter your not using as much ice. or ice maker is slightly over flilling water and dripping over rear of unit
Posted on Feb 24, 2008
  • Ron Coons
    Ron Coons Feb 25, 2008
    turning down pressure wont help, but you can try loosing the screws that mount hte ice maker and tip it slightly foward(dont worry about 3rd screw under(remove it and youll get a little play) just the 2 above loosen twist and tighten
  • Ron Coons
    Ron Coons Nov 29, 2008
    sounds as if you fill valve is bad, not shutting all the way and allowing waer to trickle in. i would repalce the water inlet valve, located behid rear panel.( where water enters machine
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Clump of ice in bucket
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Posted on Nov 29, 2008
SOURCE: Ice cubes melting then refreezing in clumps
check the flap door to see if it is slightly open letting warm air in
Posted on Aug 10, 2008
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
My GE Profile refrig ice maker makes hollow ice cubes. Why would this happen?
Not enough water is being pumped into the icemaker. The water pressure in the water line coming into the refrigerator may be too low, perhaps due to a blockage somewhere.
Move the refrigerator enough to get behind it. Turn off the water at the small valve which connects the water line from the house plumbing to the tube going into the refrigerator. Get a bucket. Remove the refrigerator water line from the on-off valve (there should be a compresson nut holding it on). Point the incoming water line into the bucket and open the valve. Do you have a good flow of water? If so, either there is a blockage in the tubing within the refrigerator or the water valve at the bottom of the back of the refrigerator is malfunctioning.
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice in the bin on subzero 632 freezer is in clumps
if the ice maker leaking it's easy to replace, or may be just a water supply tube has been moved to the side
Oct 03, 2009 | Sub-Zero 632 / S
Ice maker only crushes/does not cube
Remove the ice bin. Look at the back wall, behind where the bin was. You should see a rectangular hole, about 1.5 x 1 inches near the bottom of where the ice bin was. There should be a white plastic part inside the hole. This plastic part should be able to be lifted up with your finger, and drop down again when you release it. If is does not move, it may be frozen, or the electrical solenoid connected to it may have melted. If the part moves freely, just replace the ice bucket and try to dispense cubes again. (the metal arm sticking out the back of the ice bucket might have gotten on the wrong side of the white plastic part in back)
May 21, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Crushed Ice only
I have a similiar problem. I have dumped the ice and started ice maker again. It make ice but will not despense ice cubes.
Apr 27, 2009 | Refrigerators
Ice maker makes ice, but also drips water
cbscarter,
This may sound strange but you will find that the mold coating is peeling off of the aluminum mold. This causes the water to wick (climb) the loose coating and up over the top, leaking out making an ice clump on the ice maker and clumps ice in the container together. It would be easy enough for the average person to replace the ice make. Due to its age that would be smarter to replace than to repair the old one. It is a Whirlpool part #4317943 and comes with some instructions.
If this helped please rate me good, supertechks
Oct 11, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Aug 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Auto ice maker
reduce water fill, small adjustment screw on side of power head, clockwise for decrease, maximum one full turn. if that fails, remove i/m and check for cracked mold, fill with water and place on level table under paper towel. if ok, replace module.
Jul 07, 2008 | Maytag MZD2766GES Side by Side...
Jan 20, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana ARB1905C Bottom Freezer Refrigerator Logo
845 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
