Question about Samsung SyncMaster 731B 17" LCD Monitor
Just flashes the monitor comes on but just flashes.
  • Samsung Master
  • 3,866 Answers
Sounds like you got a bad back light or a bad inverterboard inside the monitor this can be fixed by replacing one of the two.
I sure hope this is Very Helpful for you. thanks for using fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Dec 13, 2009
SOURCE:
Monitor is slow coming on then when on website clicking out of second tab flashes black
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 26, 2014 | Acer AL1716 17" LCD Monitor
Acer x193w Monitor won't come on flashes blue light you see word "Acer" it goes to flashing Yellow light and keeps repeating that.
you disconnect the monitor from PC
& see: it will show no signal or check signal cable. that means the monitor is OK problem is in PC. may be you PC is not booting properly. if monitor does not come on there may be fault in the main board of your monitor.
Oct 13, 2011 | Acer X193W LCD Monitor
Monitor will not come on. power light is flashing
Connect the monitor to any computer having windows operating system. Load to the BIOS screen, if the display comes up, the monitor is ok, the software or the driver software for the monitor has been corrupted, else if no display comes up, the monitor has gone bad.
May 08, 2010 | HP vs19 19" LCD Monitor
FPD1975W (Black) 19 inch LCD Monitor: power button flashes but not coming on...
Open the cabinet and remove CMOS battery and harddisk connection from motherboard.
And reboot the system. It will give the msg no boot device found. Now place again the cmos and harddisk and reboot
May 06, 2010 | Gateway FPD1975W 19" LCD Monitor
My monitor power light keeps flashing. It won't
usually this is a bad power supply. most electronic shops can repair them
Jan 10, 2010 | Acer AL1916W 19" LCD Monitor
Monitor flashing at startup
When the monitor is flashing, is the flashing coming from the middle and going up and done to fill the screen. If so, probably capacitors in the monitors power supply are leaking and need replacing.
Mar 27, 2009 | ViewSonic VG900b 19" LCD Monitor
LiquidVideo monitor will not come on at bootup.
Blown capacitors internal to the monitor they can be replaced by soldering.
let me know what you want to do
Mar 22, 2009 | Computers & Internet
MONITOR MENU COMES UP BY ITS SELF AND FLASHES
There is a problem with the IC which is the driver IC. The part number of that IC is 24LC08B. It is manufactured by Microchip. I'm sure the brand of your CRT monitor is HP. I have the same problem too and HP can't fix this problem. Even their service center can't fix it also. This is the problem usually of new HP/Compaq monitors. I think this is a factory defect problem but HP isn't doing anything to repair these defective monitors. HP sucks!
Aug 24, 2008 | Compaq FS7600 17" Flat Glass Monitor
Flashing green power button
the monitor green light comes on but the monitor itself does not come on. Sylvania LCD CL722b-Model 780
May 16, 2008 | Sylvania CL772B 17" Flat Panel LCD Monitor
Red Light Flashes and monitor won't come on
Philips 42FD9934/17S Red Light Flashes (monitor won't come on).
For a while I could unplug the monitor and after several tries it would come on. Now it will not start. Would like info on what part(s) should be replaced and where to get them.
Mar 05, 2008 | Philips 42FD9934 42 in. HD-Ready Plasma...
Samsung SyncMaster 731B 17" LCD Monitor Logo
109 people viewed this question
Top Samsung Computers & Internet Experts
asber
Stormi  Paulk
Stormi Paulk
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
