Question about Panasonic NN-T993SF Microwave Oven
Stop after 27 seconds - Panasonic NN-T993SF Microwave Oven
  • Panasonic Master
  • 9,125 Answers
I've not heard of one stopping at 27 seconds.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Dec 13, 2009
Tip
I like any microwave apart from the Phillips whirlpool Vip 27
I have a Phillips whirlpool Vip 27 and it still works (which is unfortunate because I like any microwave apart from the Phillips whirlpool Vip 27) so I am wondering if I should recycle it or give it to a charity because it's got a crack in it and I like any microwave apart from the Phillips whirlpool Vip 27 I hope to get rid of it and get a new one and if the Phillips whripool 27 became available again then I would never buy it again so goodbye Phillips whirlpool Vip 27
on Nov 23, 2016 | Microwave Ovens
Panasonic genius1300w cuts off after 3 seconds
see this causes and fix it. God bless you
Door Switch If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Main Control Board If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpa
High Voltage Transformer If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermoprotector If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Thermostat If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
Oct 09, 2012 | Panasonic TK-929SA Stainless Steel...
Sensor goes off inside microwave after 10 seconds
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Oct 03, 2012 | GE Microwave Ovens
My panasonic microwave NN-S954WF will run a few seconds and then stop. What should I check?
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 2-3 seconds, see if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt http://031d26d.namesecurehost.com/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Nov 16, 2011 | Panasonic NN-S954WF Microwave Oven
We have a Panasonic Microwave model number NN-t945SFX. We were using our microwave as a Inveter Turbo Defroster as we prepared our meal. Seconds after, a family member decided they wanted popcorn since...
NN-T945SFX May 27, 2017
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
If it stops after 7 seconds, it likely has a problem with the inverter.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Panasonic Microwave Ovens
Panasonic Microwave Oven Stops After 15 seconds - Never Heats
You can order Panasonic parts from Tritronics.
If you reconsider, you can find an authorized Panasonic servicer here.
Oct 21, 2008 | Microwave Ovens
Panasonic inverter dimension 4 microwave oven runs for 27 secs in micro mode then cuts out no heat either convection oven grill work fine ????
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Sep 03, 2008 | Panasonic Microwave Ovens
Microwave Oven "Error 1"
Error 1 = Short circuit in the MW(microwave) relay.
Maybe the relay have problems in your contacts. In idle state, the relay's contact must be open.
Feb 11, 2008 | Microwave Ovens
Panasonic NN-T993SF Microwave Oven Logo
201 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
