Question about Honeywell Dryers
I HAVE TWO HONEYWELL FROST WATCH SPACE HEATERS, AND ONE OF THEM SHUTS OFF IN JUST A FEW MINUTES, i THINK IT`S OVER HEATING BUT NOT SURE . aLSO I HAVE A MASTERCRAFT SPACE HEATER THAT DOES THE SAME , PLEASE CAN SOMEONE HELP
  • 96 Answers
Your safety switch is shutting it off even if it is not overheating
Posted on Dec 13, 2009
I have a toastmaster model 2517 space heater. it comes on for a few minutes and then shuts off and then in a few minutes then comes back on. is that normal for that model? if not,how do I fix it?
it sounds like it is turning off when it reaches the temperature setting you have it at. turn it a little higher and see if it stays on longer.
Mar 05, 2015 | Heating & Cooling
I purchased the Patton PUH9000 heater last year. I puts out a lot of heat at first, but shuts itself off after about 5 minutes, then cycles back on after a couple of minutes. Is this normal operation? I...
These have poor quality safety parts that fail in about 1 season or less, the failure rate for these little cheaper units is high, go Honeywell next time!
Jan 11, 2011 | Patton PUH9000-U Heater
The heater no longer moves from side to side. It's an oscillating heater. How can I fix this?
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Oct 05, 2010 | Honeywell HZ370 Space Heaters...
The heater keeps shutting off, i unplug and wait a few minutes, then try again it works for a few more minutes then shuts off again.
Defective thermostat is shutting it down before it reaches the correct temperature. Essentially the thermostat is acting too sensitive.
Finding parts could be tricky probably worth replacing for the potential repair cost.
Jan 02, 2010 | Sunbeam LowProfile Space Heater
Sealy space heater,shuts down
the motor is going bad. I would like to help you more but really the only thing you can do is replace it and your problem will be solved.
Feb 08, 2009 | Reddy Heater-30-55,000 BTU Variable
Oil filled heater wont stay on
I was having the same problem and did a search to find this link. This morning when I turned it on, I backed the temperature down to 66 when it first came on (defaults to 70) and it appears to be working now (it's been on for over 10 minutes)
Mar 17, 2008 | Honeywell HZ-710 Oil Filled Radiator...
Honeywell surround heater shuts off
Had the same problem. The cause: The coils have too much dust on them.
Soultion: Take the bottom of the base off and clean/vacuum. While the base is off, you also have access to the interior of the heater. Remove the 2 screws on the bottom front, then the 2 on the bottom back. The plastic panels will come off and you'll have access to all internal areas. Just clean thoroughly and you should be good to go. You wouldn't realize it, but even with a spotless house, the heater will **** any small particle of dust.
Jan 17, 2008 | Honeywell Surround HZ2200 / HZ2204 /...
My honeywell heater was working one minute and not working the next.
HI I have this heater and no manual , and I was doing research on the internet and found that these haeters have an automatic shut off if it gets too hot and it wont come back on for a while until it is cooled down. I just unplug mine awhile or turn it off and then it comes back on when it cools down.
Jan 02, 2008 | Honeywell HZ335 Ceramic Compact Heater
Honeywell HZ7040 shuts off after few minutes
This sounds like a theromostat problem. If you're NOT still under warranty you should at least open the heater and look for the theromostat. A lot of times you can buy replacement at a local electronic or hardware store and they're easy to replace. Good luck!
Dec 02, 2005 | Honeywell HZ7040 Compact Heater
Dryers Logo
411 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
