Question about Orb mStation 2.1 Stereo Docking Station, Speaker System for iPod - Pink
The sound is not working on my mstation orb. If you put your ear to the center speaker, you can VERY faintly hear a beat. I've tried other ipods, connecting it to different outlets etc, but it won't work. It's barely used, unlike my brother's orb, yet it is not functioning?! Suggestions?
Mstation
Do you have an adapter that can plug it into your regular stereo? That might take care of it.
Oct 27, 2012 | Apple mStation Tower 2.1 Stereo Speaker...
The right earcup in my beats by dr dry solo hd is making a cracking sound when im turning it up and down
that is because you push all the air against the speaker. the air have to get oute somwere. i had the same broblem so i put a little peace of rubber between the ear cushion and the plastick part. so ther is a litte split. if jou has a good peace of rubber or some plastick soft foam en at the top, you just do\'nt see the split. but be carful he can drop in to the speaker. wen you\'ve don dhat you do\'nt heare it enymore if it is good. (my english is not vedry good, iam from holland) i hope it worked for you. :p
Jun 28, 2012 | Monster Cable Products Monster Beats Solo...
The speakers work fine apart from the sub component has lost all volume u can hear it very faintly if u turn the volume to full and the bass control to max. I've taken the sub apart to some extent...
Appears that the map powering the sub woofer is fubar. Those amps take a beating usually from being over driven. Transistors are not like tubes that will just reach a limit, distort, and stay there. You push a transistor and it will self destruct since it knows no limits ala evel knevil.
Sep 20, 2017 | Creative Labs i-Trigue 3400 Computer...
The speaker on my ipod plays even when my headphones are plugged in. How do i turn off the internal speaker?
un plug ear buds
reset ipod by holding menu and center at the same time for 30 seconds till you see the apple logo - - then reconnect ear bus make sure they make a clicking sound and there is no gap
play a song to test
Apr 05, 2010 | Apple iPod nano
Creature III brand new faint sound!
Check out here:http://www.fixya.com/support/t3604714-jbl_creature_speakers
Jan 10, 2010 | JBL CREATURE II Computer Speakers
Ipod dock plugged it, switch to DMPORT no sound from speakers
I had the same problem. I tried everything and finally following two fixed the problem:
Dock insert has to be put before inserting Ipod in the dock. Dock insert usually comes with iPod when you buy it....After inserting the doc I was able to hear the sound but it was very faint. Then I updated the ipod's firmware. My Ipod classic was two years old. I updated the firmware by connecting it to the PC and opening itunes. Clicked on 'ipod' link and clicked to update button.
After the update, this ipod started working with my home theater system's DMPort.
HTH.
Feb 28, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Control pod on bose companion 3
try to check the circuit board with an expert
Nov 16, 2008 | Bose Companion 3 Computer Speakers
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
Orb mStation 2.1 Stereo  Docking Station, Speaker System for iPod - Pink  Logo
Top Orb Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Orb Audio Player and Recorder Expert? Answer questions, earn points and help others
