Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Clump of ice in bucket
After we changed the water line filter for the ice maker, we started seeing clumps of ice cubes in the back of the ice bucket. It appears that the rear cubes are slightly melting then refreezing. All the other cubes are fine. Any ideas?
  • Frosty Dave Jan 30, 2008
    Multiple times a day. We usually have to remake ice every two-three days. If we don't clean out the rear cubes, the pile of cubes continues to grow! (Possible sci-fi movie plot?)
    The one thing I haven't done is totally empty the ice bucket, then tell it to make ice, then wait to hear it drop the cubes in the bucket, then see the condition of the rear cubes. I'm not usually around enough to do that.
    Thanks for any thoughts on this.
  • Gary Davd
    Gary Davd May 11, 2010
    How often do you get ice out of it??
  • Amana Master
  • 19,396 Answers
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Posted on Nov 29, 2008
2 Suggested Answers
6ya staff
SOURCE:
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Clumps of ice cubes in back of ice bucket
sounds like your just might not be using enough ice and they are defrosting and clumping together.figure your pulling ice from front of bucket the the backs hardly get used espescially in winter your not using as much ice. or ice maker is slightly over flilling water and dripping over rear of unit
Posted on Feb 24, 2008
My maytag MFI2569YEB ice cubes are melting around the coil in the tray. What could be wrong?
if you are talking about the bucket the cubes go into, most likely you do not use a lot of ice. the ice isn't melting, it's evaporating. usually winds up in a big clump at the bottom.
Oct 31, 2013 | Maytag Freezers
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
Ice maker makes ice however there is a big clump of ice stuck to the bottom of the bin. It keeps happening each time I remove the clump. I have replaced the 2 valves in the back of the refrig/freeze
Sounds as if the tray is running over. Are the cubes oversized? If you remove the cover (front, usually) from the icemaker you'll probably find a fill adjustment -- a screw with + and - markings. Rotate the screw 1/2 turn in the - direction and see if you notice a reduction in cube size. If it's running over, you may need to make more than one 1/2 turn adjustment.
Jan 10, 2018 | Maytag MSD2758GEB Side by Side...
Ice cubes are turning into a clump of ice
I found a high density foam and a plastic retainer under the freezer drawer, inspected ice maker and found a wire with a rectangular senser hanging down. Removed freezer drawer and door to gain access to icemaker. Reinstalled foam piece and plastic retainer to lower front of icemaker (there are recess and a small retainiing tab) Reassembled freezer door and drawer, system working normally
Feb 23, 2010 | Whirlpool Refrigerators
Ice maker over fills the ice cube tray over flowing into the cube collection bucket, making all the cubes one big clump
most likely the i/m needs replaced. what happens is the coating inside the mold is peeling off and causing the cubes to stick and then melt the cubes instead of releasing them. when this happens it will cause the unit to overfill the next cycle and leak into the bucket.
Jan 07, 2010 | KitchenAid KSRP25FN Side by Side...
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
My GE Profile refrig ice maker makes hollow ice cubes. Why would this happen?
Not enough water is being pumped into the icemaker. The water pressure in the water line coming into the refrigerator may be too low, perhaps due to a blockage somewhere.
Move the refrigerator enough to get behind it. Turn off the water at the small valve which connects the water line from the house plumbing to the tube going into the refrigerator. Get a bucket. Remove the refrigerator water line from the on-off valve (there should be a compresson nut holding it on). Point the incoming water line into the bucket and open the valve. Do you have a good flow of water? If so, either there is a blockage in the tubing within the refrigerator or the water valve at the bottom of the back of the refrigerator is malfunctioning.
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice in the bin on subzero 632 freezer is in clumps
if the ice maker leaking it's easy to replace, or may be just a water supply tube has been moved to the side
Oct 03, 2009 | Sub-Zero 632 / S
Ice maker freezes Whirlpool gold
try to remove all the ice in the bucket first and start all over again. the first bundle of ice could be the one making the problem. and then check the cold air vent towards the ice bucket. there should be cold air blowing to it to maintain the temperature in order for the ice not to melt.
after removing all the ice and inspecting if there is cool air coming out towards the ice bucket. let it run and observe it.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Jan 20, 2008 | Amana ARB1905C Bottom Freezer Refrigerator
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
279 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
