Question about IBM Office Equipment & Supplies
My mom's IBM selectric has 5 key's in a row that don't respond. They can't even be depressed. All others around them work fine. I didn't see any obstructions and I noticed that none of the keys can be depressed when the machine is turned off. Any ideas?
  • IBM Master
  • 3,594 Answers
My best guess would be that something fell into nthe machine and slipped over the dust cover and under yhe key levers. If you know how to remove the case and free up the T/W lift it up and look from the bottom.
DickyO
Posted on Dec 14, 2009
My IBM Selectric II typewriter skips part of a letter when typing envelopes and going over the overlapped thickness. Even repeating the letter doesn't help.
That particular key is not hitting the paper flush as it should. Carefully try adjusting it in the direction of the miss.
Nov 08, 2015 | IBM Correcting Selectric II
How do I unlock the keyboard of IBM Selectric III???
The Selectric typewriter has several "interlocks" that can cause the keyboard to be locked. When you turn the machine off there is a mechanism that locks the keyboard. When you turn it on the part should move and unlock the keyboard. Sometimes this part sticks and the keyboard will remain locked. When you type any character the keyboard is locked to prevent two keys trying to type at the same time. The machine locks and unlocks very fast. One keys is locked in and prevents others from working. try turning on the machine and hitting every key just a little bit harder and see if it then types. When you shift, as the ball is turning the keyboard is locked temporarily so it won't attempt to type as the ball is turning as that would damage the machine. Sometimes the shift mechanism can cause the keyboard to remain licked as the shift may not have finished it's complete cycle. Also, the return mechanism locks the keyboard temporarily when the carrier is returning to prevent you from typing when the carrier is moving backwards. Only a qualified technician can resolve those issues.
May 08, 2014 | IBM Correcting Selectric III Electric...
IBM Selectric III stopped working
Needs servicing. it slow up because the cycle clutch needed lube, Never leave on a selectric it will over heat the motor. and shut off totally, but after it cools it will turn on again. Turn the silver bar that goes through the carrier. a slight bit top away from you and try turning it on. May work for a bit
Mar 27, 2017 | IBM Correcting Selectric III Electric...
IBM Selectric Model 71 keys are locked up and won't depress.
First thing try every key one may be partually tripped. Try the shift key that may be out of adj. Most anything eles you will need a tech.
DickyO
Dec 23, 2009 | IBM Office Equipment & Supplies
The keys on my IBM Selectric III typewriter are frozen....is there anything I can do ???
First; depress the tab key. If that unlocks it, then you need a return clutch or torque spring replaced. Does the spacebar or tab key work? Sometimes you can gently press everykey on the keyboard and eventually one will release and unlock.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
May 14, 2009 | Office Equipment & Supplies
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
Selectric III Key Stuck
remove the cover , latch on bottom each side of unit.
turn it on is the belt running or jumped off.
if it is running then the clutch is jammed.
Jan 25, 2008 | Office Equipment & Supplies
49 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
quennie732
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
