Question about Lexmark X5470 All-In-One InkJet Printer
Refill colored ink, what holes, lexmark x5470
I don't know what holes to put the ink in
    President:
  • 2,351 Answers
To open the printer, just above the front control panel you use both hands & pull upwards. The whole top of the printer will open up. The ink cartrifges will be close to the center of the opening. The printer should be on for this. There are two ink cartrages. The one with the black lid is for your black ink. There is a small tab in front of the cartridge lid. Push down on the tab & the lid will open. Remove the old ink. Remove the tape that is protecting the the bottom & copper back side of the new ink. Place the ink into the printer. The copper back that runs from the bottom & up the back side about 3/4" goes into the printer cartridge. The colored ink goes into the other cartridge holder, it's lid is blue. Again press the tab just in front of the lid & it will pop open. Repeat the above removing the protective tape & install the ink.
The ptinter will want to run either a test page or allignment page or both. You will need your manual. If you do not have your manual you can download it from this site. Click the link below.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=f7f0a21c03aee016b79da0cdbb74cf9f&q=Lexmark+X5470
Click "Start download" & save it to your Pc.
Have fun!
please vote...
Posted on Feb 07, 2008
Instructions for refilling cartridges on a Lexmark Prevail Pro705 printer
Please note that Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. You might not get the print quality you expect from the ink that is specially formulated by Lexmark.
Feb 19, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
HOW DO I REPLACE THE INK .I BOUGHT THE INK BUT FOR GOT HOW TO PUT IT IN
In order to replace the ink..please follow the following steps
#1
Spread out a piece of newspaper where you plan to work. Remove the supplies from the refill kit. The Lexmark 44 will have one bottle of black ink, one thumb drill and one syringe. The Lexmark 43 will have one bottle each cyan, magenta and yellow, three syringes and one thumb drill.
#2
Remove the label from the ink cartridge. The black refill hole is at the top of the ink cartridge. Use a toothpick to check the color of each fill hole on the color ink cartridge. Generally, the magenta is at the top of the cartridge, the yellow is at the left center and the cyan is at the right center.
#3
Use the thumb drill to open up the fill hole to fit the syringe needle. Place the tip of the thumb drill on the fill hole and twist until the hole opens up larger. Do this for each color hole on the color ink cartridge.
#4
Fill each syringe with 7 ml of color ink (one for each color) and 15 ml of black ink. Insert the syringe needle into the bottle of ink and pull the plunger upwards.
#5
Place the tip of the syringe needle into the fill hole. Slowly press down on the plunger. If the ink seeps out while filling, stop filling the cartridge and wipe up the ink with a paper towel. Some cartridges may not need the full amount of ink. Repeat this step for each of the colored ink fill holes.
#6
Replace the ink cartridge in the carriage of the printer. Run one to three test pages to cycle the ink and check the printing. Use any document with color on it for the Lexmark 43 and any document with black text for the Lexmark 44.
Thanks
Oct 06, 2010 | Lexmark X9575 InkJet Printer
Lexmark Prnter won't recognise color when cartridge refilled.
Hi there
Lexmark and Brother printers, dont have any thing I know of to reset the inks when you refill them your-self sorry.
Pineworks
Mar 07, 2010 | Lexmark X5470 All-In-One InkJet Printer
How refill lexmark 34 & 35 ink cartridges
moz-screenshot-1.pngmoz-screenshot-2.pngmoz-screenshot-3.pngHere are links with refill instructions, with pictures :)
www.refillinstructions.com/Lexmark/L7.htm
www.refillinstructions.com/Lexmark/L8.htm
I just need to add that there is no need to leave the cartridges for 8 hours. Just pop them in after the refill, but make sure there is no leaking (either from the refill holes or the print head). You can wait several minutes to see, but there is no need to wait so long, since there is a sponge inside, which absorbs the ink you pour in.
Hope that helps!
Feb 23, 2010 | Lexmark X5470 All-In-One InkJet Printer
I have a Lexmark x5470 & I get an error unsupported cartridge
Ink cartriges have chips in them, if the printer does so many prints without getting the "I've had a new Original Cart fitted" it will stop untill,you give it one, regardless if there ink or not
Im afraid it doesn't care that you only need to use the colour cartridge, it is designed to cost you money and make money for lexmark not refillers.
Welcome to our modern world, manufactures make the ink hard to recycle by incorperation of expensive chips that makes refillers, unable to make a easy dollar, because if that want to make cartridges that work they must also fit the expensive chip.
All empty cartridges have a little ink left in them because getting air in ink lines is not a thing we want.
Nov 07, 2009 | Lexmark X4270 All-In-One InkJet Printer
Printer does not recognize carts
I have refilled my cartridges many, many times. A messy job, but well worth the savings. Never over fill, handle carefully.
The printer will give an error message, but just press cancel, do not order a new cartridge, Your refilled cartridge will work on the lexmark x5470. Good luck.
Oct 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Refilling the Lexmark x5470 color ink cartridge: Can't
There should be a dialogue box that pops up on your computer when the cartridge is low telling you to order new ones. Usually there is a box you can check to tell it to ignore that the cartridge is low. If you don't get the dialogue box, somewhere in your printing preferences you should be able to tell it to "ignore ink levels." There does not exist a cartridge that "does not contain this circuitry." There are no compatibles of these cartridges and all refills are of original manufacturer cartridges.
Jun 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
I refilled a 33 colour cartridge still says low
I would like to inform you that Lexmark printers does not support refilled cartridges. Please note that #33 cartridge is know as a rushmore cartridge and in this cartridge it has memory chip on it to identifiy the ink estimation. hence it is not possible to change the low ink indication.
Please note: using refilled cartridge may void ur printer warranty.
Apr 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470 all in one printer-low ink level
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Mar 06, 2008 | Lexmark X3550 All-In-One Printer
Lexmark X5470 All-In-One InkJet Printer Logo
289 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
