Question about Solis Palazzo Espresso Machine
Solis Palazzo with rapid steam
During the cleaning process my machine ,ade a horrible noise. I removed the inner mechanism and a part fell out of the right side. I cannot find where it came from . I attempted to contact Cafe West who was the only distributor I know of for this product and they are no longer in business. Do you know of another distributor or service center for this type of coffee machine?
Thank you!
Not sure who the distributor is but I've had luck calling 888-437-8340 and speaking to Josh or Jerry. So far they've been able to talk me through all problems.
Good luck
dgsrgr8
Posted on Jun 01, 2008
6ya staff
SOURCE:
Super automatic espresso machine leaks water into drip tray and onto counter when I use the frother
The stream valve is leaking and probably needs to be replaced. If you remove the top cover it is visible.
Sep 12, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Manual
Hold the coffee button down from the moment it is pressed till the water in the cup reaches the desired volume, then release. It will now save that volume amount to memory.
Jun 13, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Container leaking water
Ther is tank seal that is at the base of the machine where the tank goes on . it will dry up , waer out and leak overtime.
Apr 20, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Solis palazzo not producing coffee
I think the blockage might be at the brew unit, remove unit and check the screen under the red o-ring, connected to that is the chute that leads to the espresso spout. That tube might be blocked, there are 2 screws holding that piece together, be careful when you remove them do not lose the spring and ball in the fitting. Clean tube and reassemble.
May 24, 2012 | Solis Palazzo Rapid Steam Palazzo Fully...
Steam/water valve leaks water, only fills coffee to 50%, help? I have completely removed steam valve assembly to clean and reassemble. Leak persists, suspect o-rings?
Hi
If your water valve is cream or black colored, you need a new manifold. They will get hair line cracks if you steam, but don't cool them down after steaming by running cold water through them. If you have one of the new brass(silver) manifolds it could be your O-rings but i doubt it.
Oct 07, 2009 | Solis Palazzo Espresso Machine
Need to buy water tank of solis pallazzo coffee maker
The only importer of solis I know of is Barratza.com, they will have the parts needed.
May 29, 2009 | Solis Master 5000 Espresso Machine
Solis rapid Steam stuck in descaling cycle
try to run a new descaling to see if it works normal again.
/Mirran
Sep 22, 2008 | Solis Palazzo Espresso Machine
Solis pallazzo rapid steam
Hi Alex,
Try to prime the machine.
May 20, 2008 | Solis Palazzo Espresso Machine
Solis Palazzo Espresso Machine cleaning problem
Robert Harris sell this machine. Their service centre- 14 Newark place Auckland or ph 09 274 2777. They are the gurus.
Feb 16, 2008 | Solis Palazzo Espresso Machine
Solis Palazzo Espresso Machine Logo
112 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Pierre Laplante
Ekse
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
