Question about Kenmore Elite 21086
Washer kenmore elite calypso 21086
Washing machine stops in the middle of a cycle and reads (SL), i don' thave and owners manuel.. what do u think this could be. ????
  • 4 more comments
  • katriauna Jan 20, 2008
    yeah it states that it's SL.. or maybe it's 5L .. but it just shuts the washer off and makes 3 beeps.. But what does the LS mean also, just in case...
  • katriauna Jan 27, 2008
    this was helpful.. but without an owners manual it's a little difficult.. but thank you.. i do appreciate it.. i will buy a new pump and try it out.
  • gregleem Mar 15, 2008
    I have a scarf that has worked it way down beneath the tub and wrapped itself around the spindle. I need to remove the tub to get at the scarf. I have take the top off and it looks like I have to remove the agitator. How do I do that?
    Thanks Greg
  • mauri0162 Apr 13, 2009
  • robert samples May 11, 2010
    are you sure its not ls as i cant find a code for sl
  • Anonymous Mar 18, 2014
    washing machine
    President:
  • 1,314 Answers
Promblem with the lid switch is it happing durning the drain spin cycle
Posted on Jan 20, 2008
  • 2 more comments
  • robert samples Jan 20, 2008
    Suds Lock S L
    The motor controller senses a suds lock condition by analyzing the current draw on the drive
    motor. If a potential suds lock is detected, the control tries up to 3 times to clean out the unit
    with a mini-cycle. See Use and Care Guide for more information.
    “SL” is displayed if suds are detected but the unit is unable to clean out suds. This may
    indicate a bad pump, an extra heavy load, excessive detergent or excessive suds.
    Press STOP/CANCEL to clear the display.
  • robert samples Jan 27, 2008
    what kind of detergent are you using
    go here look under owners center and can down load manuel http://www.whirlpool.com/custserv/index....
    lid switch
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
What is the kenmore washer model # 21086 water pump failure error code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 16, 2009 | Kenmore Elite 21086
Kenmore Elite calypso 21086 leaves dirt streaks on clothes
Run the hottest & fullest cycle possible - without a load - and add a grease remover - like goo-gone. Fatty tissues build up inside the tub - and can be released on hot cycles if HOT wasn't used very often.
It is recommended to run a HOT load every 2 weeks or so to avoid these buildups and staining of clothes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 20, 2009 | Kenmore Elite 21086
I have a Kenmore Elite Washer that does not complete the wash
The timer should be checked/replaced.
Jan 12, 2009 | Kenmore 22422 Top Load Washer
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso Washer
I'm in the process of tearing apart my Calypso, Ugh. I found the diagnostic chart inside the machine. 5L is actually 'SL' which means suds lock, and can be an indicator of a failed pump, an extra heavy load, excessive detergent, or excessive suds. Corrective action is to press Stop/Cancel to clear the display.
Mar 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
21086 reading sl
If it is top loading one, you use powders for 'top loading machines'. If yours is a front loader pl use powders for 'front loading machines'. It makes a big difference in cleaning.
Feb 23, 2008 | Kenmore Elite 21086
Kenmore elite calypso 21086 top load
SL = Suds Lock
SL is a suds lock code it can be caused by the drain pump not draining the water, too much detergent, non HE detergent, or extra heavy loads, try running it empty, if code persits it is a computer/main controller/timer failure
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Jan 20, 2008 | Kenmore Elite 21086
FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. This could just be a fluke, or you could have a possible bad pressure switch that is not shutting off the water supply correctly. In addition, fill valves have been known to short out causing water to constantly fill in the wash tub. Lastly, your household water pressure could be too low and won't shut the fill valves off properly. Inlet water pressure should be a minimum of 10-20 psi. With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display. I hope some of this leads you in the right direction.
May 12, 2007 | Kenmore Elite 21086
Washing Machines Logo
514 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
