Question about Cell Phones
I just got a i68 - having one problem is there a
I just got a i68 - having 2 problems is there a way to change the screen shut down time? I start doing something and the screen goes black (if I push the start button 2 times it goes back to where I was - just a pain. My plantronics bluetooth has alot of static on it( it did connect). My i68 asked for a code for my plantronics but I have had that for 2 years and have no idea about a code.
Thanks for any help.
Shuts down after 1/2 hour drive
The EGR system does this to engine after running a short time. Have it checked out. The valve, solenoid, & the relay for it can all cause this problem
Mar 28, 2010 | 2000 GMC Safari
I have a ameristyles s18/i68 and i an having problems with the screen. c
Simple solution that usually works with this phone. Simply hold the side volume button down in the UP position until you see a little blue screen and then press the volume button DOWN and the calibration screen should appear. This should unfreeze you.
Feb 15, 2010 | Cell Phones
The screen shuts down after between 30 & 60 secs
This is an option for the TomTom. If you enter the Options, there should be something about Power Save features. In there, you will see options to shut off the screen, and you can have it do so after a certain time, once a certain speed is reached etc. Just change the time in which it turns itself off to never and you're fixed.
Sep 30, 2009 | Tomtom ONE GPS Receiver
My sciphone i68 says emergency calls only when i try to use it
We had the same problem on both of our new sciphones. After long hours of research we finally found an easy solution to it so hope this helps.
1) Shut down your phone completely (you will know because a red sign will come up on your phone and you have to confirm that you are shutting it down).
2) Take our your battery and then your sim card
3) Make sure that your sim card is in the right way. (It has to be on the highest slot, not the one closest to the bottomof the phone, and the metal plates have to be facing down, or towards the phone).
4) Reinsert your battery and then start your phone up again
5) Go to restore factory settings and plug in the code 1122 when it asks for one. NOTE: Your phone will reboot, and when it turns on it should be okay.
We tried everything and this is the only thing that worked. We had t-mobile sim cards for both phones and it worked fine. Good luck!
-twins-
Jun 20, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Change default encoding for a sciphone
Try to type in the following code: *#0044# - this changes the SciPhone to english language.
Find an Sciphone i68 user manual at http://chinamanuals.com inc. network settings for major providers.
Jun 03, 2009 | Dual Electronics CECT P168 Cellular Phone
Want to remove chinese apps from phone
To change to all english mode type in the following code:
*#0044#
Find here an english user manual for SciPhone i68
May 23, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
DLP Projection tv, Models WD-52631,57731,65731. The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv...
DLP Projection tv, Models WD-57731, The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv system shuts down. I reset it a few times but that doesn't change the problem
Jul 26, 2008 | Televison & Video
Sony projection big screen
does the led flash when you try to power it up? If so let me know the number of flashes. From your description I would suggest 1 of 2 things happened. (1) The Convergence amp ICs have shorted and blown the 5 amp fuse on the G board, or (2) the red CRT has shorted shutting the set down. Check the fuse and if blown replace the fuse and disconnect the Red CRT PC board from the RED CRT and try powering up the set. If it powers up without shutting down then unplug the set and rehook the RED crt pc board and try again if it shuts down the reds shorted. But if it still wont start with the CRT unhooked or blows the fuse Change the Convergence ICs
Apr 06, 2008 | Sony KP-57XBR10 57" Rear Projection...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
