Question about Samsung SCH-u740 Cellular Phone
110V ac and USB adapters for Samsung u740 don't recharge the batteries on two of our 4 phones. Can the adapter port on the phone be cleaned?
Batteries for rca cambio w101 v2
The tablet has a built-in rechargeable battery. The unit comes with an AC adapter (DC IN 5V) to recharge it via an electrical outlet in your home, or you my use a Micro-USB cable plugged into the port and plug the other end into the USB port on your PC/Mac.
If you're having issues with the battery, such that it may not have been used in a long and entered discharge mode. Connect the AC Adapter for several minutes to get it up to at least 5% before attempting to power on.
Even though the battery is a built-in rechargeable, it can be replaced if necessary, and fairly easily IF you take your time 10-15 minutes and have basic skills. A replacement battery for this unit sells for about $10 on ebay.
Jun 18, 2017 | RCA Televison & Video
Motorola A1200 cell phone battery will not charge with AC chargers
HI,
If your phone is still under warranty the best solution is to get it replaced.The problem is actually with the port of the charger.I mean the hole in which you plug in your charger isn't working properly.Where as your USB port is different and works properly so it charges the battery.So you will have to get this repaired.
Sep 18, 2008 | Motorola Mobility A1200
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
Will not take a charge. took two charges prior but has now stopped
I found this online at www.sandisk.com under warranty and manuals link.
I believe they have an excellent Return Authorization system, that if you truly have trouble with your disk player and it's still under warranty, gather your receipts and get on line to get an RMA. I have successfully returned to disc players that were infact faulty (FAT problems) and received two replacement players. Get on it right away. Look at the manaul online too. IT can be very helpful. I've included the Battery info, and the link for the manual at the end.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
May 12, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Installing micro SD adaptor
if you are holding the phone with the camera lens toward you, the micro sd slot is on the right side ...owners manual pgs 11,12
the adapter does not go into the phone
the adapter you got should be the size and shape of a regular sd card...this is for insertion into memory card reader/writers...the micro sd card fits into the top of the adapter....it just makes it easier for you to transfer images to and from your computer or separate digital camera that holds a full size sd card
Apr 20, 2009 | Samsung SCH-u740 Cellular Phone
Just wondering how to connect it to a computer?
The Samsung SCH-i730 doesn't have a USB port, but it has a different port that underneath the phone itself. You need to use an adapter so that you could connect it to the computer. Look for the adapter SCH-i730 Lil Sync USB connector.
There could be a possibility that the battery is not working correctly. To isolate this, try to use another battery to see if you will get the same problem.
NOTE: To take care of the battery, never charge it if it's not running out of charge. Never unplug the charging battery if it's not fully charged.
Apr 15, 2009 | Samsung SCH-i730 Pocket PC
Sansa clip wont power up unless hooked up to usb
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Charging
computer.
Clip player.
Sansa
adapters.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Samsung u740 cellphone
it would not cost much like about $40.00usd to replaced....so start calling around to mobile service centers close to you for a cost.
Aug 18, 2008 | Samsung SCH-u740 Cellular Phone
A/C adapter
Yes, the model is E-7AU. Use this 110V/120V AC Adapter to conserve batteries when downloading to your computer, during printing, or while viewing images when connected to your TV or VCR. The Olympus stock number is 200685.
Sep 01, 2005 | Olympia OL-5805 Cordless Phone
Samsung SCH-u740 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
