Washing machine clothes getting grease stains during wash cycle
  • 2 more comments
  • Anonymous Apr 14, 2008
    I am having the same problem. I have tried EVERYTHING, i haven't used fab softner in 3 months, ran it empty with hot water and clorox, use more detergent, use less detergent, wipe the rubber seal out everytime, NOTHING will help. I HATE this Fridgidaire Affinity washer!
  • berproechel Jun 29, 2008
    I also get grease streaks on my clothes some of the time. I have totally wiped the interior, door gasket and cleaned the dispensors. I emailed the manufacturer and haven't had a response.
  • qhmath Sep 19, 2008
    I get the same thing with mine. It has ruined several of my shirts this way.
    I know it is not bleach... because I have never used bleach in this washer.
    I don't have clothes with stains going in, but I have stains on some when they come out. It doesn't happen every time, but it has happened enough times to really tick me off - and ruin a handfull of my shirts.
    Does anyone have a solution for what this could be caused by??
    I forgot to mention - my washer is a Kenmore Elite Oasis HE... I don't know if that matters?
Hi, Ross from Reno here. My buddy and his wife have had some of their clothes ruined by grease stains from their front loader Kenmore. The unit is about 6-7 years old and was making quite a racket in the spin cycle. It wasn't an overnight thing, but got louder as time went on. Switching detergent didn't solve the grease problem and all they could wash at home was work clothes that didn't matter if they were stained. Yesterday we dragged the thing into the garage and took it apart. If you are even somewhat mechanically inclined and have a fair amount of hand tools available, you can fix your machine, IF it's the same problem we faced. The bearing in the rear of the machine had 'spun'. The drum of your washer is mounted on a couple shock absorbers at the 5 and 7 O'clock positions as well as suspended by two springs at 10:30 and 1:30. As you are aware, this allows the drum quite a bit of movement, but if you reach in and grab one of the plastic 'wipers' and pull/push the drum quickly, see if you feel and/or hear any sloppiness. My buddy did this to his and then went down to Sears and tested a bunch of new front loaders in the same way. Not one of theirs had any slop. Again, you don't need much talent to do this job, in my OPINION. It may be intimidating, but if it's fix it or spend a grand on a new one... So the first thing to do is remove the bottom front cover, two screws in our case. Then came the top cover, two hinges on the back need to be unscrewed and then it lifts (from the rear) and slides forward to sort of unsnap. Finally the rear cover, 10 screws, easy. The belt comes off, then the pully. There's a water hose up front at about 5 O'clock that needs to be removed. If it makes you feel better, take pictures along the way to help you remember what goes where, but really, it's pretty straightforward. The drum has concrete weights bolted to it to help quell vibration. The only one we had to remove was the top rear weight. We chose to disconnect the lead to the motor and pull it with the drum rather than try and unbolt it inside the machine. There are other things that need to come off, but you'll see them. We also unscrewed the top brace in the rear of the machine and flopped it, and its attached wire loom, forward to make a little extra room. Next came the springs. These aren't like the springs on your car, but still you want to exercise some caution. You can now unpeel the rubber door seal from the 'face' of the washer and shove it inside the drum out of the way. The last thing we did before removing the drum was to disconnect the shocks on the bottom. They have plastic dowls holding them to the drum and the chassis. You'll need someone lifting on the drum to take the weight off the attach points. On the left side (as you face the washer) we pushed (from the front) the bottom dowl out to free that shock, and on the right we accidentally pulled the shock apart. It split in two pieces like a toilet paper holder used to. It takes a couple people to do the grunt work here. It's not all that heavy if you're 24 years old and 180 pounds (I'm neither), but it's cumbersome. With two guys though the drum came out the back with no problems. Now you can see light at the end of the tunnel. It's only a matter of splitting the plastic case which contains the drum (20 some odd screws; power tools are wonderful here) and CAREFULLY tap/pound the shaft which connects the drum to the pully. A plastic mallet or a peice of hard wood helps prevent damage to the shaft. You need to have the drum up off the floor on wood or something, again preventing damage. Once apart what we saw was a destroyed bearing on the 'drive' shaft. It took a couple minutes of heating the bearing with a small propane torch but it slid right off. The bearing is molded into the plastic outer case, but my buddies had frozen and spun leaving remains stuck to the shaft. I would guess that his is a rather extreme example of how bad it can get. We cleaned up the shaft as best we could with emery paper, and could have reused it, in my opinion, but he decided to replace both, the rear outer case which holds the bearing (you cannot buy just the bearing) and the shaft, which also cannot be purchased separately but must be bought as a whole with the inside drum. They each cost about $200 for a total, in our case, of $420. It went back together easy, even the shock we pulled apart. We used some rubber cement on the rubber door seal, let it set for about three hours and then did some clothes. You'll want to do a load of work clothes first if you are buying a new shaft/drum like we did. It had a light film of oil on it. If you are using the old drum you will NEED to clean all the old built up grease and detergent where the bearing seats on the shaft. You'll see it. A screw driver and high pressure hose will do it. Again, work clothes first. We had a leak on the first run, but it was just the drain hose at the five O'clock position that I didn't get tight enough upon reassembly. We're now washing good clothes in relative quiet. I would have to say that ours was a worst case scenario. But still, three hours labor and a little over $400 ($200 if we had re-used the old drum/shaft) beats the **** out off what a service call or a new machine would have cost. A couple things; have a printout of your machines internals handy, both for reference and to make it easier for the parts counter guy when you go to get the new stuff, and there was one twist tie kind of clamp holding the detergent supply hose that was a bit of a struggle. It took the two of us to get that little ******, but a small straight slot screw driver proved invaluable. All in all it was a cake walk. Hope this helps someone out there save some money and clothes. Ross
Posted on Apr 17, 2009
A407 maytag washer getting grease on clothes occassionaly what would the replacement part
Maytag washing machine gets grease on clothes ... - Fixya
Oct 8, 2012 - Maytag washing machine gets grease on clothes occasionally. ... some of their clothes ruined by grease stains from their front loader Kenmore. .... remove the agitator from a Maytag washing machine Model A407 series 02?
Aug 24, 2015 | Maytag Washing Machines
OIL STAIN ON A CLOTHES out of washing machine E12477
Are they getting the oil stain from the washing machine? If so, you need to get a tech out to inspect your washing machine. If you are putting oily clothes into the washing machine hoping it will come out, it's too late, you need to pre-wash with Shout or Tide to remove oils and grease. The more you wash and dry it the deeper the stain will set. Sounds like you need to throw those clothes away.
Jan 20, 2015 | Washing Machines
My Haier washing Machine vibrates and makes a very loud vibration noise.
Have you noticed any grease or oil stains on clothes coming out of the washing machine?
In my personal experience, heavy vibration and loud noise during spin cycles has been caused by the bearing being broken and further damage caused by running on a broken bearing. If that is the case it is a costly repair, I had to get a new washing machine.
Washing machines are simple to take a part to a small extent, just remember in what order you took things off if you decide to investigate further your self.
Dec 15, 2014 | Haier Washing Machines
Oil on cloths after wash
Simpson washing machines are known for this, The seal in to top of the gearbox fails which allows water to enter the gearbox, this forces the grease out of the gearbox into the machine, The fix is an expensive gearbox swap.
Mar 11, 2012 | Simpson Washing Machines
Oil/grease stains on clothing
Dryer is much more likely
Nov 28, 2011 | Washing Machines
I am getting stains on my dark clothes that look like oil stains.
Check that the dispenser is clean, it may be gunged up with black gunge, use soda crystals and put machine on hottest wash. If all is clean it could be down to seal gone in drum letting grease into system. Good luck, let me know how it goes.
Sep 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Dark Grease stains on my Kenmore Front Loading washer
Dec 13, 2008 | Washing Machines
Washing machine stains clothes
You can pull the agitator straight up and off to check if there is any grease / oil on the bottom of it. You may have to use a belt or similar item to slip under the agitator and attach the other end to a broom handle to pull up if it is difficult to remove. If there is grease / oil, it is not very easy or inexpensive to repair. The average life of a washer is about 9 years, so this one doesn't owe you anything. I'd look into a new front load unit which uses much less water and spins clothes out at 2X or more the RPM's of your current machine. Please don't rate this solution as anything but a FixYa rating will lower my overall score. Thanks.
Nov 19, 2008 | Washing Machines
Washing Machines Logo
1,065 people viewed this question
Top Washing Machines Experts
