Question about HP Pavilion dv6000z Notebook
Hi my hpdv6000 laptop is showing black screen,what to b done?
  • 154 Answers
First we need to test if the problem should be the LCD screen. The easiest and most foolproof method for testing your lcd screen is to hook up the laptop to an external monitor. If the video output on the external monitor looks fine, this means that the problem is with the video connector, with your LCD panel itself, or with the circuitry that turns on the LCD.
Second we need to disassemble the laptop and find the video connector
on the system board (if the video is integrated on the motherboard) or on the video card that is attached to the motherboard. Try re-connecting the cables. You may as well locate the display connector on the back of the end LCD panel. Re-seat that one too. This way you can be sure that the problem is not related to connections.
Every now and then the switch located on the system board that turns the back light of the LCD on and off can become stuck. If this is the problem then your LCD never powers on. There's a little switch that detects whether the screen of your notebook is open or closed. That's the one we're talking about. Try to push it down and hope it gets unstuck.
Disassembling the laptop to unstick this switch is an option, but sometimes you can get away with not taking it apart. Try lightly hitting that plastic switch. But wait, this isn't the only possible cause, unfortunately. Re-seat the other connectors and cables that are present around the LCD panel and the video on board (including the inverter).
Posted on Dec 14, 2009
I have VGA to an HDMI cable when i hooked it ho tv it still show black screen no signal
Hi.
You will need to tell the laptop to switch displays from the laptop to the TV screen, this is usually done by holding down the FN key and pressing one of the F keys. With HP laptops this key is usually the F4 key.
Regards.
Jan 29, 2013 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
My laptop shows a black screen when i switch it on,it only shows the mouse at the top
To solve the issue try the below step,
* Unplug the power to the PC
* Remove the battery
* Then hold the start button on laptop for 20-30 seconds
* Once done the above step, continue with installing the battery again and power lead.
* Then simply power on laptop
Oct 15, 2010 | Computers & Internet
Hi my screen is black when I turn on my laptop.
ysounds like you either have to replace the backliught tubes and/or the circuit board that runs the backlight tubes.backlight tubes are available on ebay from a gentleman in oklahoma city oklahoma
Jun 23, 2010 | Dell Inspiron 710m Notebook
Black streak thru my screen. what can i do
Plug an external monitor into the VGA-output port.
If the black-streak shows up on the external monitor, it's your computer, and maybe the video-adapter, that is the problem.
If there's no black-streak, then it's your LCD-screen that is damaged.
It will cost about $200 for a replacement screen, and about $60 for an hour of a technician's time to open-up your laptop, remove the old screen, install the new screen, close-up your laptop, and to test it.
Or, if your computer is still under warranty, it may be possible to get the repair ($260) done via the warranty.
Dec 29, 2009 | Acer Aspire 6930-6771 Laptop
Will the Led be exspesive to buy
Do you mean the LCD screen on your HPdv6000? The screen can be bought on E-Bay for less than $100.00. The DV6000 isactaually an easy laptop to change the screen on.
Nov 11, 2009 | HP Pavilion dv6000z Notebook
I have a hpdv6000 series laptop and recently it
Hi:
I believe that your LCD panel is the problem, but you should verify that you have good video, by toggling to an external monitor to check your output. If it dispays good, you have an LCD problem.
Nov 10, 2009 | HP Computers & Internet
HP Laptop HPdv6000 Display Issue
Start your unit in safe mode and see if the line still appears.
F-7 will get you into safe mode..
If you still have the line, it is a video problem and my need serviceing.
If not, you should try re-installing your firm ware.
Sep 21, 2009 | HP Pavilion dv6000z Notebook
No visual display
It sounds like your graphics card is shot. If your graphics card is a dedicated graphics card, you might be able to get it fixed/replaced; if it is embedded, then you are probably going to have to buy a whole new display screen.
Sep 04, 2008 | IBM ThinkPad T40 2373 Notebook
Cant download anything hpdv6000 to my sandisk sansa view
Install Media converter, then connect sansa. Then, it should appear in My Computer as Sansa View. You can add it there or use the converter software.
Aug 10, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
HP Pavilion dv6000z Notebook Logo
112 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
